Kawasaki GPZ250R I have a Kawasaki GPZ250R that keeps on filling the airbox up with oil via the crankcase breather. Is the supposed to be a vavle that stops this happening?
  • sroldfield Feb 04, 2008
    Thanks for you excellent response - much appreciated! This has only happened since doing an oil change so I also suspect option1 - however, we drained the oil and only put in 1.6ltrs and it still does it - I wonder now tho' if draining oil by removing oil filter plate drains less that using the drain plug? Will investigate - cheers
    Brigadier General:
  • 6,966 Answers
A very light very thin film of oil inside the airbox is good/normal since this help absorb dust that is not filtered in the air. Too much though is an indication of something is not quite right inside the crankcase. This could either be:
1. too much oil in the engine;
2. carbs varnishing. This is related to fuel overflow right into the Venturi entering the cylinder and into the crankcase. The oil gets saturated;
3. engine overheating and cooks the oil.
Of the above, I tend to suspect the first. Kawas of this design are meant to have oil filled to the halfway mark of the glass window when the bike is on its center stand or completely upright.
Alternately, if you warrant a temporary remedy, a small PCV valve placed in line with the breather should prevent oil coming back out. These are oneway valves and will only allow air to come in but not out.
Another is to cut short the breather and install a small K & N filter while plugging the other half going to the airbox.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
P.S.
Doing wheelies could also be the cause.
Ride Safe.
Posted on Feb 04, 2008
  • Louie  Role
    Louie Role Feb 04, 2008
    Hi again,
    Appreciate your post back for update info. One of my bikes, a ZZR, has basically the same engine and manual says needs 1.9liters of engine oil. Everytime the oil is changed, what will drain out would be less than 1.9 liters. I suspect that a good amount would be left above the cylinder head or in the oil galleries. Normally, I change oil after a good run (to make the engine really hot) and leave it overnight draining.
    I have removed the airbox and replaced it with two (2) K & N airfilter slip-ons. The oil breather is likewise terminated using a small K & N filter.
    Hope this be of further help/info.
    Would appreciate if you can rate this response as you see it fit.
    Cheers.
Wrong site friend.
6ya staff
SOURCE:
Pulled drain plug and oil and gas drain out....how is my gas getting mixed in with my oil. 2000 r6. Thanks
WHAT TYPE OF BIKE DO YOU HAVE THIS IS TYPICAL OF FLOODING CARBS WHERE FUELGOES INTO AIRBOX THEN IN TO ENGINE VIA CRANKCASE BREATHER?
Aug 20, 2016 | Motorcycles
2006 Kawasaki KX 250 F oil is leaking out of the crankcase breather tube
Hi, Anonymous and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
oil coming out of brether hose
oil coming out breather hose need help
http://www.mx-sport.ru/files/servicemanual-KX250f-06.pdf
OEM Parts for Kawasaki
2006 Kawasaki KX250F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 07, 2014 | 2006 kawasaki KX 250 F
2002 Kawasaki VN 1500 Vulcan Classic oil blew out at the breather hose when cranked
Hi, Anonymous it's called "WET SUMPING" if left sitting for weeks or months will eventually let the oil tank contents drain pass the oil pump check ball and fill up the bottom end of the crankcase when the bike is started the excess oil will gush out of the breather vent and if routed to the air cleaner will also flood the filter. This messy condition will continue until the bottom end is forcibly emptied by the flywheels or manually drained if there is a plug. There are 3 options you may want to consider:
1. Drain the oil tank before storing the bike.
2. Replace check ball and resurface seat in the oil pump.
3. Install inline ball valve shut off in the feed line to the pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Crankcase breather hose Kawasaki Vulcan Forum Vulcan Forums http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/12214-crankcase-breather-valve-marbelized-breather-hose.html
Kawasaki Vulcan 1500 Classic Fi Service Manual
2002 Kawasaki Vulcan 1500 Classic Owner Manual
Mar 09, 2014 | 2002 kawasaki VN 1500 Vulcan Classic
2001 Kawasaki ZX-6R Ninja oil leaking from the breather
Oil Leak is this the airbox KawiForums Kawasaki Motorcycle Forums
Oil in carb and air box easy fix ZX Forums
Kawasaki Ninja ZX 6R Service Manual
2001 Kawasaki Ninja ZX 6R Owner Manual
Feb 01, 2014 | 2001 kawasaki ZX-6R Ninja
2000 Kawasaki ZRX 1 breather hose gushing oil
Hi, Wanda and the usual suspects are:
Thread has oil leak
Crankcase Vent
2000 kawasaki zrx1000 service manual Google Search
2000 Kawasaki ZRX1100 Owner Manual
Sep 28, 2011 | 2000 kawasaki ZRX 1100
2001 Kawasaki EL 250 Eliminator V oil coming out of the breather
Hi, Bidie46 and the usual suspects are:
2001 Kawasaki EL 250 Eliminator oil coming out of the breather Google...
DOWNLOAD NOW EL250 EL 250 Eliminator 250HS Service Repair Workshop Manual... $15
KAWASAKI EL250 Owner Manual
Feb 22, 2010 | 2001 kawasaki EL 250 Eliminator V
XR650R oil and creeking
the oil in the air box is not a bad problem alot of 4 strokes do this its a breather that comes from the crankcase to the airbox.. and the creaking noise is probally the linkage have the bearings replaced and greased
Aug 30, 2009 | 2000 Honda XR 650 R
CRF 450 IS LEAKING OIL TROUGH CARBURETOR
Hi there
You should not have oil leaking from the carby. If you have over filled it with oil, then it may be coming from the crankcase breather and then into the airbox, and appearing to come from the carby. If you have not over filled it, then the bike may have blowby problems with compression gasses passing the rings, and in a similar manner forcing oil out the crankcase breather. Not sure about the hole in the side of the cylinder... do you have a picture? Unless its pouring out, or gets worse, I would not be too worried. If you have over filled the oil, maybe time for an oil change to get the level right.
regards
robotek
Dec 06, 2008 | 2005 Honda CRF 450 R
Oil sump mod or fix
Deep sumps are to keep the pickup in the oil at all times even when the front end is way off the ground - I don't think it'll have any effect on sending oil out the crankcase breather. An aftermarket tail-mounted breather box will keep oil out of the airbox but it's expensive probably hard to find nowadays, and forces you to reroute a lot of wiring as well as relocate your computer box. Simpler to just do fewer and smaller wheelies,,,
Nov 10, 2008 | 2001 Ducati 996 S
Oil sump mod or fix
Open Questions:
Computers & Internet Logo
164 people viewed this question
Ekse
Marvin
Marvin
