Question about Maxtor / 80GB / 7200 / 8MB / SATA-150 / OEM / Refurbished with NCQ (RB6B080M0) Hard Drive
Problem with my external hard drive.
It is my first time to use this 80 gig external hard drive but when im trying to put the cable to my pc it hangs.i was trying to used it but my computer doesn't open now.whats wrong with my computer.i cnt also use my external hard drive.
  • 43 Answers
The HDD is corrupt.Try to re-format if you get your PC to open.
All data will be lost.
To be honest with you,I would not now trust the HDD for any critical or confidential data.
Posted on Feb 04, 2008
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
80 gig maxtor not reconized in computer bios cmos
check the cable & more better way use duel usb cable which occupy 2 usb & i Normal Hdd connector
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Additional Hard Drive
The Motherboard will be able to handle it and XP will read the hardrive i have used a 500 gig hard drive in my old computer before it should work just fine
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
80 gig maxtor
change hard board or
change your cables (date & power)
Oct 27, 2008 | Maxtor Hard Drive
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Sep 06, 2008 | E-Machines eMachines Desktop PC
External hard disk
the Hatachi 80 gig looks the same as the 120 gig verbatum 47558
also had the same blue flashing light and no recognition by XP
I open the case and removed the drive from the pc board. cleaned the contacts and reconected the PC board , the fault was oxidisation
May 30, 2008 | Computers & Internet
Samsung SP8022N / Hanaro 2
ok.
ok you said that you have hanaro 2 and you want to sasve something to that drive.
this is what you got to do set your hard drive as slave. ok
Jan 26, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Simpletech pininfarina problem
It appears that this is happening a lot with external drives. Inside most of them is just a regular internal drive. In my case I simply removed the drive from the external enclosure (a SimpleTech 160 Gig) and installed it in my PC, where it works like a charm. Most people who have this problem go out and buy a replacement generic external drive enclosure for about $30.00.
Jp
Dec 05, 2007 | SimpleTech Pininfarina 80GB External USB...
La Cie External Hard Drive 160 gig
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
Jun 07, 2007 | LaCie (300740) 160 GB Hard Drive
Maxtor / 80GB / 7200 / 8MB / SATA-150 / OEM / Refurbished with NCQ (RB6B080M0) Hard Drive Logo
81 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
