D-Link DI-624 Air Plus XtremeG Wireless 108G Router
Problem for D-Link DI-624 Air Plus XtremeG Wireless 108G Router...
No internet connection through di-624 from laptop
By buck1965 on Feb 04, 2008
I've had dlink since Dec 07 all was fine for a couple of weeks, after that I have not been able to access the internet from my laptop. I did some trouble shooting by checking all connections,resetting the d link,both work fine. I uninstalled and reinstalled the wireless lan card program for the laptop (7 times) but no link or connection. I tried reconfigureing the wireless setting ,which was mostly guess work. I decided to see if ip adresses were an issue and I am unable to find any adresses at all. Iam all guessed out, what should I do?
Clarification Request
Posted by TeK Micro on Feb 04, 2008
Have you tried connecting the laptop to the router using an ethernet cable, and were you able to get internet access this way?
Same Problem
Apr 08, 2009
-   My internet connection works fine with the ethernet cable plugged in to the laptop but as soon as I remove it it doesn't work. Do I have to set up a wireless connection? And if yes how would I do that? -   Arnie_Pie
May 27, 2008
-   not working -   elhijoelupe
Solution #1
posted on Jun 14, 2008
Not Rated)
rahul26485
Rank: Wiz  D-Link Expert
Rating: 79%, 385 votes
if you give the automatic ip address obtian throught dhcp in that you give proxery server if there then remove it . and go to the router page and go to dhcp in that you enable and give the dns there and ip address you isp . then you get it after then you not get it then disable the proxery server. in laptop give both automatic.
Was this helpful?
Yes
No
Popular Solutions for D-Link DI-624 Air Plus XtremeG
Questions and Unsolved Problems for D-Link DI-624 Air Plus XtremeG
Do you recommend D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)?
Answer
Answer
Basically we've tried the put in our IP address into the browser adn got into it, we've also changed... (More)
Answer
how do i now put one in i set up my router without a password ?
Answer
This is a home network. The DI-624 will disconnect users at multiple times during the evening hours,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repairmen
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
