Question about Compaq (283983-001) Motherboard
COMPAQ Evo D310st
I have a EVO D310 Compaq and I am geting the following error during the post: 511 & 512: cpu & chassis fan not detected, and press F1 to continue. The fans do work and I even tried replacing them and I still get the message. what can i do???
  • bvillen Feb 23, 2009
    Mine is Compaq Evo D510 have same problem(512Error) replaced battery,re-done bios,still same,maybe the motherboard is k-put.
    bvillen@intergate.ca
Also it must just be a loose cable, hanging inn such a way as to prevent the fan from turning. That's what I found when I got this error message, a loose power cable was resting against the fan blades. I just moved out of the way, and all was back to normal. (I had installed a new graphic card and RAM, and didn't notice cable interfered with fan when I put closed computer up.)
Posted on Oct 29, 2011
    Genius:
  • 1,226 Answers
Please go to Bios setup and then Load the bios set up default, and restart the system.
If this not work, Please replace the CMOS battery maybe that battery is busted. and the do again"
"Please go to Bios setup and then Load the bios set up default, and restart the system. "
hope this help!
If not solve the problem please notify me, do not rate.
Posted on Feb 04, 2008
  • athangte Jan 23, 2011
    My computer is 510 and I have the same problem, but when i replace the Intel Fans nothing pop up. These motherboards demand Intel Original.
  • blueseaaa Mar 10, 2011
    I also have EVO D310 Compaq and same problem facing. I set its bios default and replace the battery but problem remain same. Please let me know what should I do ?
I got a compaq evo n110 the cpu fan doesn't turn anymore
Try changing the fun first if the problem still persist then it could be a problem with the broad see a specialist for that.
Feb 27, 2012 | Compaq Evo N110 Notebook
I have faced a problem on Compaq Evo W4000 that there is an error i.e 1801 microcode patch error so how i can remove that error
Give a try to update BIOS. Click here and follow the intrsuction
  1. Obtain a formatted 1.44-MB diskette and place it in your A: drive.
  2. Download the SoftPaq to a directory on your hard drive. The file that is downloaded is an executable with a filename based on the SoftPaq Number above.
  3. From that drive and directory, execute the downloaded file and follow the on-screen instructions to build the ROMPaq diskette.
  4. Place the newly created diskette in the A: drive of the computer to be upgraded or restored and cycle system power to boot from the ROMPaq diskette.
  5. Follow the on-screen instructions to select the Compaq System ROM and flash the firmware. WARNING: DO NOT TURN OFF POWER OR ATTEMPT TO REBOOT THE COMPUTER DURING THE UPGRADE PROCESS!!!
May 10, 2010 | HP Compaq Evo w4000 PC Desktop
Missing Multimedia Audio Controller (device manager) I'm running windows xp ver 5.1 sp2 Compaq 0804h motherboard Need a Multimedia Audio Controller for Evo Compaq d310 PC Microtower
Best place to look is the Compaq website. If you cannot find it there, you could try using a driver finder program to locate the right driver for your sound card. Those programs will identify the hardware by device id and use that together with the Windows info to get a matching driver.
Apr 23, 2010 | HP Compaq Evo D310 PC Desktop
How to fix error 512 for evo d310 I replace chassis, rear chassis, or front chassis fan but still error I wont to fix it not show any error thank
Error 512 is a common Windows error. Error 512 is usually caused by missing system files, wrong system settings or a corrupted registry file. Run a registry scan to check for registry errors & other system problems. 90% of the time this will fix the cause of the error.
Optimize PC programs might do the trick, some are free to download.
Jan 13, 2010 | HP Compaq Evo D310 PC Desktop
When i put on my computer, this message apear : 511-cpu fan not detected. I have a Compaq Evo D510 CMT and i use Windows Xp. Thaks for the help
This will likely be caused by a loose connection, if you look inside the machine there should be a cable running from the fan on top of your cpu to the motherboard. If thats disconnected or loose then plug it back in and all should be right with the world!
Dec 24, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
I need a manual for Compaq Evo
Please download the manual from the below given URL, I hope this helps you know your system.
http://www.manualshark.org/p/hewlett-packard-28/hewlett-packard-compaq-evo-d310-micro-desktop-26933/
Sep 22, 2009 | Compaq Evo D500 PC Desktop
Cpu support
hi,
It will be supporting till 1.6 ghz pentium if u will put a processor from outside
Mar 03, 2009 | HP Compaq Evo D310 PC Desktop
Error 511
It means the 3 pins for that fan are not working on motherboard . I suggest you use the motherboard 3 pins for the chasis fan and buy a CPU fan with 4 pin setting that connects to your power supply ( much better current )
Jul 11, 2008 | Compaq (283983-001) Motherboard
Compaq Evo D310M 845G P4...
Best bet would be to hit up ebay for this and look on there for spare parts.
Just take what you posted in the title and hit ebay.
Note: prices may vary and if you bid be sure you are getting a working board.
Nov 29, 2007 | Compaq Evo D310M 845G P4 Motherboard
Compaq (283983-001) Motherboard Logo
1,861 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
