Question about RCA D52W19 52" Rear Projection Television
RCA D52W19BYX1 ITC222 I KNOW ITS THE FLYBACK TRANSFORMER BUT I NEED HELP
OK I GOT THE FLYTRANSFORMER OUT AND ORDERD A NEW ONE BUT IM NOT SURE IF IT THE RIGHT ONE I WENT TO PARTSTORE.COM AND THE PART NUMBER THEY GAVE ME IS #259296 IS THAT THE RIGHT ONE THE ONE IN THE PIC DONT LOOK THE SAME IM NOT SURE IF IT IS JUST AFTER MARKET OR THE WRONG ONE I SEEN SOME WHERE ON LINE THAT THE PART NUMBER AT PARTSTORE IS #265409 BUT WHEN I CROSS REFFENCE IT IT"S NOT THE RIGHT ONE CAN SOMEONE HELP THANX RUSS...
  • 1 more comment
  • JERZEY Feb 04, 2008
    I TRYED 2 FIX MY ORDER AT PARTSTORE.COM AND THEY KEEP TELLING ME THAT THE PART # 259296 IS THE RIGHT ONE FOR MY T.V. AND THAT THE 265409 WONT FIT THE D52W19BYX1 ITC222... WILL THE PART # 259296 WORK? THE NUMBER ON THE OLD FLYBACK TRANSFORMER IS 10799630 40351A-1 MADE BY OREGA IT HAD 2 WIRES COMEIN OFF IT AND IT LOOKS LIKE IN THE PIC THAT THERE IS ONE SPOT FOR THE MAIN LEED AND NOT ONE FOR THE FOCUS SORRY TO BE A PEST BUT I WANT TO GET THE RIGHT ONE PLEASE CAN SOMEONE GIVE ME SOME DETALES ON THIS PROBLEM I AM HAVING WITH PARTSTORE.COM IS THERE INFO WRONG OR RIGHT I THINK IT THE PART 265409 I NEED AND THEY KEEP TELLING ME ITS THE 25926.....
    this is the old one on partstore.com it looks likes there is a copper wire on the outside of i guess its the heatsink or magnet and this one dont have one will the one with the wire on it work what is the diffrents?
  • tubtxib Aug 10, 2008
    where did you order this part?
    President:
  • 1,284 Answers
ASTI flybacks and RCA TV's don't mix. We have seen nothing but problems with them. OEM is the way to go if possible.
Posted on Feb 08, 2008
  • RCA Master
  • 5,138 Answers
Call Asti flyback replacement company for correct flyback they may have it in stock .number 1-800-221-1828 .ThankYou for using FixYa and Have a Nice Day! If they dont have it in stock let me know .
Posted on Feb 05, 2008
    Genius:
  • 1,694 Answers
Russ,
Happy to see you doing research.....
The Drawing number is KEY.....
Dobbiins99506 solution is correct....
Drawing # ...10756 = 259256
Drawing #....10799 = 265409
Drawing #,,,,10906 = 270125
PS. I have 35 years experience correctly sourcing OEM parts.
  • Vista Electronics Feb 05, 2008
    CORRECTION ....10756 = 259296.............................T.
    265409 is what you want.......Andrews Electronics will verify..
    Call 1-661-257-7700.........Ext 213 CD tell him Terry sent you.
  • 113 Answers
259296- draw # 10756-48xxx
265409- draw # 10799-63xxx
270125- draw# 10906-33xxx
This should get you the part you need.
Posted on Feb 04, 2008
My mom has a RCA HD61W66 and the picture was showing red, blue and green "lines and shadows" as if the picture was warped. It has now stopped showing a picture at all but the power is working....
The flyback transformer has solder cracks around the pins and most likely blown the FL231 Micro fuse to the right of the flyback.I would inspect the flybacks solder. The FL231 and the CL230 and DL231 should also be replaced ( near the flyback) You can get the ITC222 Convergence option missing repair kit from www.tvrepairworld.com under the RCA repair kits. The kit contains the parts and the CD with repair instructions
Sep 15, 2011 | RCA HD61W66 61" Projection HDTV
Is it hard to change the flyback transformer RCA D52W19BYX1
no you can easially do it yourself. You can get the 259296 flyback kit from www.tvrepairworld.com which also has the step by step instructions on CD
May 09, 2010 | RCA D52W19 52" Rear Projection Television
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
Rca 61 projection not powering on
what is the issue? The flyback is the transformer that generates the high voltage needed for the picture tubes. the itc222 rca chasis can have problems with flyback but they are notoruis to trouble shoot. if if it is you flyback then you will possible have other issue like the horizontal ouput transistor. I work with these alot here at the shop. what is set doing .. does the led flash .. give me some more information and lets see if we can fix this
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Chassis # was ITC222.
Okay the flyback is the HV transformer.I am enclosing a picture the flyback is circled in RED.62bec1a.jpg
Jul 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca d52w19
You can change the HV splitter first,then change the flyback
transformer, if necessary.......Do be careful with part number
of transformer....check the drawing number on it ......10756 =
259296.......10799 = 265409......as examples..........
I can check on that for you based on your info................T.
Feb 09, 2008 | RCA D52W19 52" Rear Projection Television
ANYONE KNOW HOW TO RESET THE PASSWORD ON A RCA D52W19BYX1 ITC222
On page 40 or your owners manual it says...from MENU go to parental control then at same time press the chan. up and the vol. up buttons for 8 seconds. then you can reenter a new password...Use the ch+ and vo+ on the front of set.
Feb 06, 2008 | RCA D52W19 52" Rear Projection Television
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
2,509 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
