Question about Acer TravelMate C110 Tablet PC
Dvd not reading
I hav a dvd writer that is not reading . that is when i put a cd into drive then a message is apeared "the dvd writer has only a write permission or read permissionn what i do?
    Genius:
  • 1,226 Answers
YOu should be administrator log -on to grant you all the priveledges.
If not work then, you should re-install all the drivers of your laptop. The CD/DVD uitilities was enclosed in your laptop.
hope this help! Please notify me b4 you rate so that i can give another solution on that matter. melnavz
Posted on Feb 04, 2008
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
CD DVD drives
try antoher cd-rom to see whether it's the optical drive or the pc>>>
May 25, 2009 | Tablets & eReaders
HP Tochsmart DVD-RW drive not playing cd's /dvd's
The best player is Video Lan Controller (VLC) is plays everything.
You need the RIP command as you have not a data disk but a multimedia disk (.CDA) file.
Jun 13, 2017 | HP Pavilion TX2000Z Tablet PC
"D:\ is not accessible" message
If the cd is in the drive then you have a problem with the drive itself. It might work on a cd but won;t on a dvd. That indicates the heads have gone out of alignment.
Usually means you need to replace the drive.
Jan 06, 2009 | Toshiba Satellite R25-S3503 Tablet PC
My pc cdrom/dvd drive failed to read my recovery cd
Are you attempting to boot from a bootable disc? A failed drive can cause the other on the bus not to work. Try each one separate set as master or cs (cable select).
Oct 04, 2008 | ViewSonic Tablet PC V1100
Cdrom drive and dvd drive won't read any cd
it is probably the hard drive failing as all of the items you have tried are on the hard drive
take it to a computer repair shop for a proper diagnosis
May 18, 2017 | ViewSonic Tablet PC V1100
Hello i hv a acer travelmate c110tci and i hv a problem with it!
Your Acerf C110TCI will not succesfully run Vista. It does not meat the minimum requierments. It may load, but you won't like it. Stay with XP and SP3, it will be much better.
Thanks
Brian
Apr 11, 2008 | Acer TravelMate C110 Tablet PC
Cannot Load Windows/Windows Setup Does Not Detect Hardrive
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
DVD WRITER
What kind of plug in are you using to hook to you computer a Usb, If so go into your device manager and look into the usb settings when the dvd is plugged in and turned on, Now find the device you plugged in you should see it in the under the usb tab and open the plus + sign then make sure you are online and try to update there see what happens, If that don't work go into your control panel and go to the add and remove hardware and use that to install drivers for the dvd writer it should install them there If not let me know we will fix it somehow if that don't work, Thanks for reading my solution and Have a Happy Holidays
Dec 15, 2007 | Acer TravelMate C110 Tablet PC
The DVD drive for my Averatec C3500 does not eject.
First check the bios settings, set to the default settings.
You can dowload a bootable linux CD from here:
http://www.knoppix.org/  (I recommend the v3.3)
If you can use a cd with that it is a software problem.
Nov 11, 2007 | Averatec 3500T60 Tablet PC
Acer TravelMate C110 Tablet PC Logo
76 people viewed this question
Top Acer Tablets & eReaders Experts
Marvin
Marvin
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
