Question about HP DeskJet 3940 InkJet Photo Printer
HP 3940 Carriage stalled issue...
I'm getting very frustrated with my printer.
Problem 1. Printer carriage stalled. It does this every time I want to print something and I can't figure out what is wrong.
Problem 2. Printer is out of paper. I have paper in the paper tray inserted correctly but it still reads as no paper. Than when I do finally get it to print it sucks all the paper up all at once!
What is going on here?
  • say_mike24 Mar 15, 2009
    everytime i want to print a document "The Carriage is stalled" always appear and i can't print my documents...
Check if it has pieces of paper or stranger materials in the carriage, check also if it's moving freely (disconnect the power from the printer and move the cartridges by hand).
The unit that holds the cartridges is the responsible of all the printer workings (loading paper, cleaning the cartridges, etc.) if it's not moving correctly, the printer wouldn't work.
Probably your printer needs a technician to clean and service it.
Posted on Feb 04, 2008
HP Officejet Pro K8600 CARRIAGE STALLED
Make sure that you have tried the steps in the following web link:
https://support.hp.com/in-en/document/c01287261
If the issue persists, then this is a hardware issue. From my experience Carriage Stalled errors are usually due to a hardware failure.
Regards,
Dr. Tony
Mar 04, 2017 | HP OfficeJet Pro K8600 Printer
Tip
Carriage Jam Error on HP Printer There is nothing much to do if you get a...
There is nothing much to do if you get a Carriage Jam error. We can give a try to solve it ( Usually carriage jam error results in Hardware failure )
Follow the instructions below to resolve Carriage Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges. Check for any paper pieces, if so, remove them.
  5. Move the carriage manually 5-6 times from left to right.The carriage should move freely. ( Do not apply force )
  6. If the Carriage does not move freely, try to remove the cartridges and close the rear and front access door.
  7. Power on the printer and it will prompt you for missing cartridges.
  8. Install the Cartridges.If it does not prompt you for cartridges missing, you will find Carriage Jam Error on the screen
  9. This indicates the printer is faulty and needs repair
In any condition if you are not able to fix the issue, Contact HP ( 1-800-474-6836 ) If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer
Regards,Ron
Please rate this solution if it resolved your problem
on May 20, 2011 | Office Equipment & Supplies
Very often I am getting a "carriage jam" notification and there is no carriage jam. I free up the carriage and sometimes it prints and other times it takes four or five actions to get the...
Try this fix: Using a soft cloth moistened with water, clean the thin plastic strip you'll see along the path of the ink carriage. Be gentle and wipe gently. Move the carriage over and clean the part you uncovered, There may be residual ink that will cover some of the fine lines on the strip that the printer uses to move the carriage.You should use latex gloves as that ink can get on your hands and it doesn't wash off easily.
Feb 18, 2011 | HP Officejet 6310 All-In-One InkJet...
Hp business ink jet 2800 printer carriage stall clear carriage obstruction press resume to continue
i get this message on my printer
carriage stall clear carriage obstraction
i change the prints head and the colours catrage and still have the same message
can u help me
Jun 30, 2010 | Office Equipment & Supplies
I replaced my color cartridge on my HP Photosmart C3100 series printer and now it is making a grinding sound, but prints perfectly fine - what is the problem?
You would want to try and reinstall the print cartridges. It is possible that something is just stuck that is why you are hearing the grinding sound.
Let me know.
Apr 06, 2010 | HP Office Equipment & Supplies
My HP Deskjet 3920 shows error "The carriage is stalled." Now how can I print ? Please solve problem
Any more info?
Has it been printing ok until now? Has it not been used for a while?
Try turning off printer, then re-boot computer.
If still a problem, open the top of printer and put ONE drop of fine oil (sewing machine pref) on the two metal rods the carriage slides on, then turn on and off printer after closing lid, carriage should move.
Try printing again
Feb 17, 2010 | HP DeskJet 3940 InkJet Photo Printer
Message says carriage is stalled
Please Click Here and follow the instructions on the document to resolve this issue.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
HP Business Jet 2800 stall error message
See http://fixyourownprinter.com/forums/inkjet/42029
"Carriage Stall or Jam" by Stephen
Clean encoder strip with clean water, clean rod with denatured alchol you can get at Home Depot and lube with Synthetic Lubricant that you can purchase at a gun shop for about $4.
Mar 12, 2009 | HP Business InkJet 2800 Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP DeskJet 3940 InkJet Photo Printer Logo
617 people viewed this question
Seeker5211
Seeker5211
