Question about Honeywell Programmable Thermostat Heater
Honeywell TH8000 5 wire
Trying to replace thermostat. Had a Honeywell 7 wire setup, trying to go to TH 8000 5 wire. Had it hooked up and the heater worked. Tried to turn the AC on and it won't work. WTF is the deal? I hooked it up differently and popped a fuse. Replaced the fuse, now nothing works...heater, AC, fan, nothing...any ideas?
  • johnwayne Feb 04, 2008
    Dude, I have no idea....
    the old one was:
    X - Blue
    W2 - White
    R - Red
    G- Green
    O - Orange
    Y - Yellow
    E - Black
    The old has a light and selection for EM HEAT. I live in Texas, so I hear, that I don't need the emergency heat.
    Does this help?
    Oh...the system is all electric...
    Problem Solver:
  • 30 Answers
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Posted on Feb 04, 2008
I just installed a new Honeywell thermostat on Saturday and it stays on for about 60 seconds and shuts off. I have the heater on 90 and it is 48 in my home. The heater does not kick on. What should I do?
Th e first thing I would recommend doing is to remove the cover from your thermostat and the three or four screws that secure base to the wall .Check to see that all wires are hooked to proper terminals. On most t-stats the R.c and Rh should have a jumper wire And red hooked to R.
To make sure you did not get a bad t-stat I would dissconnect all wiring from t-stat after noting how it's wired now. Then I would hook red and white wires together.This should
turn your futnace come on and run. If it does then I would just get t-stat exchanged.Hope this works for you. Good luck and thank you.
Jan 24, 2011 | Honeywell Programmable Thermostat Heater
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
I am trying to change Lennox to Honeywell
Just remember what wires went to which terminal. Usually color coded, red =R, white = W, etc, Shouldn't be too hard. Let me know if you run into a problem.
Jan 02, 2010 | Honeywell Electronic Programmable...
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Jan 11, 2009 | Honeywell Electronic Programmable...
I'm trying to hook up a honeywell touchscreen thermostat and need to know what wires go where.
i have a vison pro th8320u and i cant get aux heat to operate also aux heat on will not come up on the touch screen.
Jan 04, 2009 | Honeywell Electronic Programmable...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
454 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
