Question about Creative Labs ZEN Vision:M Digital Media Player
No power or lights
My son plugged in his Zen Vision M and it went dead.Now we plug up to charge and it does nothing.There is no blinking light no icon to show charging.Absolutely nothing.I know the power cord works because his brother has one too.I have even tried the reset button.Can anyone offer any advice?
  • Gingerjake Feb 04, 2008
    Exactly the same problem with my Zen, however it is impossible to connect to the PC and at the same time trigger the reset button due to the reset button's location
    President:
  • 4,402 Answers
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Posted on Feb 04, 2008
Creative zen 4GB will not turn on, only blue light!!
yeah i know. i love zen too!! let it run dry and try recharge.
worked for me once
good luck
Jun 30, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
I had a similar problem with my Zen Vision:M, whereby the computer just stopped recognizing my device. I found out it was because Windws has updated to Service Pack 3 automatically, and for some reason my player only works with SP2. It started working again when I installed SP2 again, but then I keep getting the annoying upgdate notifications from windows.
May 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
ZVM won't charge
Usually this problem is due to the firmware. If you upgrade the firmware to version 1.62.02, this problem usually will disappear. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
Here is what you'll need to do to save your Zen: you will need a charger for the operation. I recommend buying a brand new charger from the Creative Labs website or a used one here, instead of getting an aftermarket one off Ebay. Aftermarket ones tend to cause problems or fail to work altogether.
Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected the charger. Once it is powered on, connect the USB cable to your computer.
If your Zen does not power on when connected to the charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
Download the firmware to your PC, then reboot your PC and connect the Zen via USB cable. Open the firmware icon to begin the download.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Oct 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN GONE HAYWIRE
sounds like it might be either a bad firmware driver, which can be erased and reinstalled via the USB connection to your computer and a download from creative. Or the battery has gone bad, in which case you have to have it sent to creative for Repair.
Jun 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision M - Dead Machine
unfortunately,the best solution is to send it back to creative for them to check it out. this sometimes happens when the player has been unused for too long and battery "under charges", which there is a solution.but seeing as u used it under normal conditions,that cant be the problem
Jun 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m - dead
Sounds like its dead. Which could just mean the motherboard is shot and needs to be replaced. Hard to tell when it doesn't respond at all. You'll need to either take it apart and replace the motherboard, or send it to a technician who can. There is a chance though that the zen is too far gone to fix. 50% of the time, when a zen won't even power on when connected to a power source, its too far gone to fix.
Sep 15, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
66 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
