Question about Olevia LT26HVX 26 in. LCD Television
I own a Syntax 26in HD-Ready LCDTV
It is less than 2yrs old and all of a sudden today the color is ALL screwed up. I have tried many times to change it by using the different menus/selections but nothing is changing it. What could be the problem or solution? Thanks
  • 1 more comment
  • kimberle32 Feb 04, 2008
    There is Blue and Yellow, an undertone of green but no red. DVD's play with color. XBox360 plays with color. But when we are watching straight tv on YPbPr2 the color is how I described.
  • napa Feb 04, 2008
    Though my TV was purchased in May, 06, it only has about 10 hrs. of use. The colors are oversaturated except on some commercials. I have tried making adjustments but I can't get the picture icon to light up so I can use that specific menu. Main problem, I can't find a repair place that will work on this TV because of poor support from Olevia. Any suggestions?
    Napa
  • kimberle32 Feb 05, 2008
    I doubled checked today to make sure I had all the connections and found that the red cable in the box had indeed been pulled. Thank you so much for your help!!!!!!!!!!!!!!!!!!
  • 113 Answers
Describe what it looks like a little more. Is there a lot of one color? Need more of a description. Does this happen on all inputs and with all sources IE..dvd,cable,vcr
Posted on Feb 04, 2008
  • Anonymous Feb 05, 2008
    Have you already checked the cables coming from the cablebox and made sure you havent lost a cable...try dumbing it down from component to composite and see if this effects it. could have lost a color output on your cable box.
6ya staff
SOURCE:
Is toshiba regza 40LV685 HD ready or full HD?
Refer its user manual for details. See its specification page. Try this link to download the manual. http://www.regza-asia.com/pdf/LCDTV/AV600/AV600_OM.pdf
Jan 26, 2014 | Televison & Video
LG HDTV LED
Sounds like you might have a defective unit, or the source that is connected to your tv (cable box, dvd etc) is going out. A lot of times if you have a cable box, glitches, loss of sound and/or color are because of the quality of the input source. Try changing the channel. If the problem is the same on any channel - or on your dvd/xbox, then it is probably a defective tv. You may be able to get it exchanged through LG. Hope this helps! Good luck!
Feb 04, 2012 | LG 42SL9000 42 in. HD-Ready LED TV
I have a olevia tv and the color of the tv is green how can i fix the color ,after comcast fix something in the signal the tv color is green
I have a 532-b12 so it may be the same - but not sure. Push the small round "menu" button on the remote. A pinwheel should show up in the upper left corner. Use the up/down and left/right arrows to go to picture. From there, you can change, saturation, color, contrast, etc.
Jan 22, 2011 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
My 26in Protron lcd has sound but no picture.
the symptom of the flash will be faulty invertors. start checking power supply output and resistance across invertors
Mar 31, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Picture looks like a Colored Negative
so, how can i fix this problem with my tv. the tv comes on but the colors look fuzzy..help!!
Oct 27, 2008 | Syntax Olevia 50" Rear Projection...
I have a Philips LCDTV HD ready and i have broken th eremote control. Where can i buy a replacement?
You can get a replacement thru any reare many on the reputable Philps Stockist,
Take the model of your machine to them should be able the source a replacement thru the store,
An alternative is a learning remote,the many brands on the market today,
Search your model number and brand for compatible solutions available,
Hope this helps
Jul 18, 2008 | Philips Televison & Video
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
We need a large display Simple to use remote for insignia lcdtv 26in. Of course the code for the tv is needed.
Go out and buy her one of those super cheap Universal Remotes. They cost less than $10 and work great (if you get a decent one) for just about any TV & LCD TV. And the cheap ones generally don't have all those crazy menu option buttons all over them. There's one I saw at Lowes that looks a lot like a flip-up cell phone. The basic buttons are on the outside and the "extra" buttons are on the inside. I learned just recently that to program an Insignia LCDTV to a Universal Remote you use the Mitsubishi Code.
Jan 19, 2008 | Insignia LCDTV26 26 in. Television
Olivia multi-media TV/monitor
Not really. Repairs are right about $150 - $250. Resistor Kit, Caps., maybe other parts, and labor charges.
Jun 27, 2007 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Open Questions:
Olevia LT26HVX 26 in. LCD Television Logo
188 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
