Question about Fuji FinePix S5000 Digital Camera
Lens does not retract
I dont know how but my camera was shut off with the lens in extended position. I am able to put on the camera in play mode but it is unable to transition to the photography mode.
Any suggestions on solving the problem.
  • Anonymous Feb 29, 2008
    I have the same problem my camera will not go into picture mode but I am able to view pictures that I have taken in the past.
I have the same problem, any help would be much apreciated.
Posted on Feb 12, 2008
Kodak easyshare Z650 lens extends and retracts
I only can think of two reasons. The first, the battery does not have enough power. As a safety precaution it shuts itself down, to avoid damage to the saved pictures. Because if the voltage is to low, it can't write with 100% accuracy.
Second: something is blocking free movement of the lens. This could have a cause inside the lens barrel, and you won't see a thing. It also could be a minute damage on the outside of the lens. Or what sometimes happens while putting the camera on, you touch the lens barrel. I assume you did remove any lens cap attached to the camera.
So if you can't see any damage to the lens barrel, charge the battery and try again.
Jan 30, 2014 | Kodak EasyShare Z650 Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Camera dropped, lens won't retract or expand
Sounds like the lens got bent out of alignment. Call Canon at 1-800-828-4040. They are really good with their support with or without warranty. You can send it in for repair or ask for the Canon loyalty Program. You trade in your broken camera and they'll give you a newer model for an incredible price.
Sep 05, 2008 | Canon PowerShot A560 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
EasyShare camera lens is extended and will not retract, camera will not stay on either
There is not repair you can do The lens mechanism had failed Contact Kodak re your next move - repair or replace
Aug 03, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
42 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
