Question about Hobart A200 Stand Mixer
A200 problem I have an older model mixer that appears to be an A200. The serial and model # are missing but I went to Hobart.com and matched the look. We use it for pizza dough only. It would not turn at all in 1st to 2nd under a load but appeared fine in 3rd. With no load it would turn but I could hold it with my hand an stop in first two gears. I have it tore down now and can't find any shaved pins. Any suggestions on what I might look for and where I can find diagram for reassembly? Thanks, Mike
  • nalaruss Feb 05, 2008
    I went thru it today and found a sheared key on one of the two smaller shafts that are offset in the top of the mixer. I replaced the key and now have found a diagram to make sure I get things back together properly. Thanks
  • aldenkent Feb 26, 2008
    I have the same problem only in first gear.I took the machine apart and cleaned it all up and checked the gear shift to make sure it moved the clutch up and down.All the pins look like they are in place but i'm not sure about the clutch gear moving up and down.
    Genius:
  • 1,665 Answers
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
Posted on Feb 04, 2008
Very old a200 ml#....?
Go to this site it is the parts list for the A200 and the A200T
http://hobart.co.kr/manual_pdf//013.pdf
Then go here for parts and parts number confirmation
http://www.food-equipment.com/parts_Hobart_mixers.htm
Hope this helps if so let us know.
Sep 20, 2012 | Hobart A200 Stand Mixer
Hobart mixer
hi Gassman, below you will be able to find a link on parts assembly for the mixer, you will have an idea on how to tear off the parts, get them cleaned and place them back, like a regular maintenance.
Hobart A200 Mixer Parts Assembly
More parts assembly for Hobart A200 Mixer
hope this helps.
Aug 19, 2008 | Hobart A200 Stand Mixer
Hobart A200 mixer 1st speed doesn't work 2nd and 3rd work fine
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
It could be the gear HM2-748
Feb 22, 2010 | Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Feb 23, 2009 | Hobart A200 Stand Mixer
A200 electronic start switch
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
Feb 09, 2009 | Hobart A200 Stand Mixer
Mixer speed selector lever
Hi. I live in Canada. I called my Hobart Parts people and they tell me that your shifter is obsolete and the shifter is no longer available in North America. I have the same model as you. For your information, the Specifications # is 3943 and your mixer was manufactured in 1966. Your serial # is 1648855. The age of your unit pre-dates the ML identification numbering system.
The newer shifter you speak of is not compatible with your machine as hobart also made transmission changes when they built the newer model. It will not mate with your machine, so save your money and don't buy the new one. Your shifter lever is made of Aluminium.
You have 3 options.
1. Check around the Wholesale Restaurant Equipment places if you have any nearby and see if they have the part you're looking for. Often times they keep some of the old parts from obsolete machines that they can no longer repair.
2. Find a local welder who can weld on a short piece of aluminum to the remainder of your shifter or if you have the piece that broke off, weld that back on.
3. Search eBay.com for the original part. There are many thousands of these mixers still in use, and you might get lucky and find the lever.
If you found this solution helpful, please rate it as fixya. Good luck! ricardok45
Feb 02, 2009 | Food Mixers
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
A200 HP rating
yes the early models had 1/3 the later 1/2 but I think it was more a marketing thing to keep up with competitors the 1/3 always worked fine
Oct 28, 2008 | Hobart A200 Stand Mixer
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Feb 18, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
354 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
