Could be a bad light switch in the driver's door. You can check and see if you have power on the driver's door with a tester before you purchase a new switch.
All of these functions are controlled by a central electronic module referred to as the BCM (body control module), you must have the dealer scan this module and run it through an active test to see what is wrong, it may be a defective BCM causing this, but that needs to be programmed and is not a plug and play part.
You have a dome light/door ajar switch that is defective, the switch is a tiny micro switch attached to the door latch assembly inside the door, to replace it requires the door panel be removed.
Could be the fuse, identify the fuse and with a fuse puller or a pair of needle-nose pliers, remove the fuse, if the wire in the fuse is broken, it's bad.
My power locks, windows didn't work and the dome lights would not turn off after closing the door. I removed the black boot that was attached to the drivers door by lifting upward and pulling away from the door. A heavy gauge black wire was broken. I removed about 3/16" of insulation from both ends of the broken wire and connected them by using a connector that both ends are placed in to and then "crimped" both ends so the broken wire made contact with each other and everything worked perfectly! The hardest part was replacing the boot. Total cost to fix is $0.50.
There is a electric contact in the door to turn on the dome light when open and off when closed. It sounds like that switch is bad or the wire attached to it has fallen off behind the doorsill. It may be another door though, since all work the dome light. Try opening the other doors one by one to see if they light up the dome. Theres no guarantee because the seat or seatbelt may come into effect.
