Question about RCA HD50LPW175 50" HDTV
HDMI What would cause the HD to stutter when the HDMI cable is plugged in,when it is unplugged no problem, but no HD
    Master:
    Sergeant:
  • 440 Answers
Bad cable not version 1.3 ok try new cable verison 1.3 hi bandwith cheak sound out put settings on teh unit are they on dolby digital thx nick .
Posted on Feb 04, 2008
6ya staff
SOURCE:
My Comcast remote quit working with the cable box. The guide wont come up any more and my hd doesn't look like hd....just standard. I went to look in the back and I thought I had hd but I only have coax....
You need an hd cable between your cable box and tv. They don't provide them for free. Once you plug in your hdmi cable to the tv, change its input to the hdmi port you just plugged into. The guide is updated by the cable system on their internet but over the coax. Give it time, it should come back. If not, reset the cable box by unplugging itfrom the wall power, wait 5 seconds, plug it back in. It should come back.
Sep 02, 2017 | Televison & Video
Panasonic 42px60u HDMI ports and HD picture wont work.
Using a box of some kind? try unplugging that and wait then plug back to see if the issue is the box. It will try to reboot.
May 26, 2012 | Televison & Video
HDMI input blown, no HDMI image..
we have to unplug the hdmi cord at the cable box and plug back in . Try it, I just figured my set is on it's last leg
Sep 06, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
Ring of death
If you only got One ring its E74, has to do with scaler chip or Gpu,
TRY unpluging av cable, clean it plug it in.
Also if using HDMI or an HD cable swich to normal AV cable input, If this works you have a broken HD, HDMI cable.
Aug 27, 2009 | Microsoft Xbox 360 Console
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection....
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
May 11, 2009 | Vizio L37 Television
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
Wesitinghouse 37" all of a sudden wont work with hdmi cables plugged in. only picture with component cables in. ps3 wont work individually either currently have it directly into cable source and everything...
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Apr 13, 2009 | Westinghouse LTV-37w2 HDTV
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
RCA HD50LPW175 50" HDTV Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
