Televison & Video Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony color rear projector model kdp-51ws550 seial 9710095 manufacture june 2004 it turns on and it goes off the stand by light keeps blinking
Mukesh Kumar
Level 3:
  • Master 3,230 Answers
  • Posted on Jan 05, 2010
Mukesh Kumar
Master
Level 3:
Answers
3230
Questions
0
Helped
902838
Points
9207
Well If you simply push the power button on the front, does the stand-by LED turn off or start flashing? Anyway the G Board is definitely suspect. Try measuring the 5 volt DC stand-by power supply. That is best done at connector CN605, between pin 10 and cold ground (any metal chassis part).
If that voltage isn't there, carefully measure the voltage across resistor R607 ( not to any ground). You should get something very low, a couple of volts (if that much). If you get a couple hundred volts, that resistor is open, and that happened because transistor Q601 shorted.
Note. You need a ohms meter to check that all. please do not try this if you do not know how to do that.......
Please post comments for more help or information........
Good Luck!!
Thanks
My sony kdp-51ws550 turns on and then dies in seconds. what is wrong with it??
most likely bulb is going bad and internals are dusty helping overheat the already used bulb.
3helpful
Sony TV
hello AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly
regards
shaun
1helpful
My service tech said my d-board can't be replaced/repaired
He was wrong, Sony doesnt have them any longer, But you can get remanufactured ones that have the same warranty as the new ones used to. Check with www.tvrepairworld.com They should be able to get one.
2helpful
My Sony KDP-51WS550 wont turn on anymore. The Standby light is flasshing 10 times.....Any ideas about what happened and how to fix?
Type in space bar Understanding sony Blinking codes this will take you to a website telling you what each code means.
4helpful
2answers
My SONY HD projection TV KDP-51WS550 (2005) suddenly lost the picture and the Stand By /Timer light starting flashing 5x and then repeating. The next morning the TV came on and the flashing stopped. Turned...
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
2answers
Sony tv
The problem you have is with the G1 board. The 17 volts is not supplied. Do you have a multimeter and know how to trouble shott following a service manual schematic? if not call a pro to assist you as this could be the G1 board, but to be sure, you will need to troubleshoot and check some voltages and follow circuit flow using a schematic diagram.If you can then let me know..
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
