Question about Sony (1-796-293-13) Plug-In Module DVD Drive
Unable to read files from some dvd
Hello..i m having trouble with my sony dvd RW ..it shows some dvd as empty and wenever..i click der it show write file to this dvd cld u plz sort out this prob thanks...
  • pankyy Feb 05, 2008
    thanks
  • 871 Answers
Hi there
Playing DVD on a computer can be complex, and involves many processes, each dependent on the one before it. Sometimes a DVD is released that includes features so advanced that some hardware may have a difficult time reading it properly. If the drive’s manufacturer has been advised about the issue, they usually release an upgrade to the firmware of the DVD drive to correct the issues.
Firmware is the control software in a storage device, and contains coded instructions for recognizing the contents of whatever disc is inserted. It is referred to as "firmware" because it is not stored on a disc itself, but rather a hardware chip inside the drive’s housing. Other devices, such as ZIP drives, CD-ROM drives, floppy disk drives, and even hard drives, all have their own firmware as well. This is a crucial component when using disc-based media. Fortunately, the chip that stores the firmware information is designed to be "reprogrammed" with new instructions, should problems arise. If this situation exists in your computer, then it is possible that the manufacturer of your DVD drive has released an update that corrects the problem.
so my advice, check your manufacturers site if there is a firmware upgrade for your dvdrom. and always put in mind to clean your rom.
hope this helps.
fixya!
Posted on Feb 04, 2008
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
CAN NOT READ SONY DVD-RW 1.4 GB DISK FROM COMPUTER DVD WRITER
your dvd has scratches on it. See if it is visible then it can not be repaired
Oct 03, 2009 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
Will not read any media dsick in DVD combo drive
The disk should actually show up in the My Computer window as a removable drive. Right click on the icon, and select explore.
You should be in the file now.
Mar 16, 2009 | Averatec Refurb Centrino 1.3GHz 512MB 40GB...
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Device stopped to read any disc
for EnzoMolinari
u r drive is having an hardware problem just contact nearby service center
Apr 27, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Compac Presario V2000 DVD CD read problem
ok sir witch company your DVD - RW first telme ?
ok any one open dvd drive clean lenss with cottin net fit same dvd use the dvd & cd data check data cable. open carefully ok you don't know contact H/W Eng : if Any Problam My email id : uday_uday2004@rediffmail.com
Apr 02, 2008 | Computers & Internet
Contents not shown blank.....
CDROM CAN NOT READ CD'S Try cleaning the lens using a high grade CD Lens Cleaner.
Sep 16, 2007 | Sony (DRU720A) DVD±RW Dual Layer...
Cannot read the min handy cam dvds
The disc needs to be finalized before you play it on other equipment. But to do this will render the disk unusable- If you intend to record over it in time, So it is best to copy the info across to the PC- burn that to a disk and finalize it then most other DVD players[Not all] will run it.
Aug 14, 2007 | Sony (1-796-388-13) DVD-RW Burner
Optorite DD0401 DVD +/- RW
Right click My computer>Explore, and see if your dvd writer is showing as a DVD RW drive and not a CD Drive, then come back
Nov 14, 2006 | Optorite (dd0401) DVD±RW Burner
Computers & Internet Logo
67 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
