Question about Polaroid FLM-2601 Television
No power just dead, even when using the remote and the t.v. power button
THIS IS A POLOROID T.V. FLM 2601 I BELIEVE A 26IN.
AFTER A YEAR AND A HALF, JUST ALL OF A SUDDEN I TURNED THE T.V. ON RED LIGHT COMES THEN GOES OFF WITH REMOTE AND T.V. POWER BUTTON. WE EVEN UNPLUGGED THIS AND SWITCH THE ON AND OFF CIRCUIT BREAKER, PLUGGED BACK IN STILL DEAD..
WHAT CAN I DO I PAID 800 DOLLARS RIGHT AFTER KATRINA HIT US AT WALMART.
  • SISSY0 Feb 04, 2008
    HI DUMMERNICK,
    I HAVE THE T.V. APART, CAN YOU TELL ME WHERE THE TRANSFORMER IS AND WHAT IT LOOKS LIKE SO I CAN GET A PART NUMBER UNLESS YOU HAVE A PART NUMBER SO I CAN LOOK THIS UP ON THE INTERNET
    WARM REGARDS SISSY0
  • 871 Answers
Hi there
seems that your Polaroid FLM-2601 Tv is having problems with the the fuse that is inside the tv, ehat you can do is check or manually open the tv and check for blown fuses and while your at it, check for blown capacitors as well.
This usually happens whenever we encounter power surges that in smaller quantities, doesnt hurt our appliances at all, but in considerably higher rates like of a thunderstorms or any sudden climate changes, this would hurt and dissable our appliances.
So, i suggest that if you can check your tv out first and diagnose those that i sited above, do so, but if it stil has the same problem, you may want to bring it to a service center instead.
again, thanks for reading. hope this helps.
Posted on Feb 04, 2008
  • earl norman llanera
    earl norman llanera Feb 04, 2008
    Ohh. so this model straight away have no fuse problems, thanks for that Drummernick :)
    So a probable cause for the irregularity SSISYO is having may be straight away to the transformer. maybe heat related issue as well.
    Master:
    Sergeant:
  • 440 Answers
Ya bad transformers in these models sad to say cost around 200 local tech shop take it in these are the cheaper line know for having bad power
Polaroid FLM 2601 flat panel TV won't turn on
Power supply board is dead.Replaced the power supply board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 18, 2010 | Polaroid FLM-2601 Television
My 26" lcd television FLM-2601 polaroid is not working it constantly stays in standby mode you push power button and blue light flicks on then goes right back into standby mode how do i fix this?
First of all, check your input source on your TV.
Turn on TV.
Press the Input button on your remote.
Make sure the Source Input matches the corresponding device that is wired on the back of the TV.
Nov 12, 2009 | Polaroid FLM-2601 Television
My flm-2601 lcd tv blue indicator comes on when you turn the unit on but the tv shuts off after about 5 seconds.
This unit most likely has a bad inverter PCB found on the far left of the set viewing it from the back. Go to www.partstore.com They carry a lot of parts for the Poloroid brand set. Thanks
Nov 02, 2009 | Televison & Video
Need code for flm 2601 to program direct tv remote
need code for flm 2601 to program direct tv remote
May 07, 2009 | Polaroid FLM-2601 Television
Flm-2601 will not power up
That particular Polaroid is, to put it bluntly, a piece of **** and never should have been unleashed on the public. Your problem is most likely the power supply and it's a module plug and play repair. Check Shop Jimmy for a used one first at about half the price of a new one. Might even order two because it will go again. Not a matter of if - it's when.
Hope this helps!
Bill
William Rayburn, CET
Premiun Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 29, 2008 | Polaroid FLM-2601 Television
Doesn't turn on
Pretty good chance the power supply board is bad. A number of capacitors will become leaky and you lose all power. Some techs still know how to do component Laval service but most just change the board $$$$
Jul 10, 2008 | Polaroid FLM-2601 Television
Polaroid FLM-2601 Power
First off replacing the caps is not easy even for a tech. Double surface boards are soldered on both sides. The caps have a value printed on them like 1000@63 They also have polarity " they have to be put in in a certain direction" If you do something wrong you blow the works. Best to have it done by a tech.
Jul 07, 2008 | Polaroid FLM-2601 Television
Power problem...
i just repaired mine by replacing the 2 electrolitic caps on the power supply that had a bulge on the top. they were 1000uf at 35 volts---works again!!!!
Jan 06, 2008 | Polaroid FLM-2601 Television
Need to buy a new remote
Try Vance Baldwin a parts dist in florida
the handle Polaroid tv's
Oct 21, 2007 | Polaroid FLM-2601 Television
Polaroid FLM-2601 Television Logo
103 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
