Question about Canon GL2 Mini DV Digital Camcorder
Canon GL2 NO POWER, NO FUNCTIONS
The unit will not power up at all. The lock switch is not in locked position. The battery has 8.2 volts The power pack supplies 7.5 volts. Unit has no sign of life. The path guides on the tape cartridge are in the fully loaded position, as if there is a tape inside. However there is no tape inside.
I used a small battery to run the loading motor to return the path guides to start position, in hope the unit was out of time, and needed to be reset. Still no power. Do these have mode switches that go bad like on vcr's?
Anyone have a service manual they could email me, taftdavid@hotmail.com Anyone have any tips,or fixes on this model
Thanks
Dave
  • 1 more comment
  • kgcent Nov 20, 2008
    My canon GL2 would turn on in the video mode but not in the camera mode for a few times but then went totally dead.
  • chalz1092 Dec 09, 2008
    mine is only going onto the video mode and when i switch it to camera nothing happens
  • mariaca May 11, 2009
    alguien save como resetear una canon gl2???
    tiene dos dias marcando condensacion y ya hico todo lo dice el manual...
    Gracias
  • 12 Answers
Hi david;
There are a few floating around some of the forums but getting one is not going to be easy. I can see if I can find you one. Ill post here if I do.
Posted on Feb 04, 2008
2007 Saturn ion 3 door locks fuse location
Power door lock's are controlled by the BCM - body control module . Are you familiar with automotive electronic's ?
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Front passenger door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Body control module (BCM)--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• Body control module PWR 15A fuse--Located in the body control module fuse panel, supplies power for the door lock system
Door Lock and Unlock Operation
The BCM PWR fuse supplies battery positive voltage to the BCM for the door lock system.
The BCM supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position, the reference voltage is taken directly to ground and the BCM senses 0.0 volts on the signal circuit. If a door lock switch is placed in the unlock position, the reference voltage is taken to ground through a 1.5K ohm resistor that is internal to the door lock switches and senses approximately 2.9 volts on the signal circuit. This is how the BCM determines what portion of the door lock switch was activated.
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
Vehicles without keyless entry have two internal drivers in the BCM to control the door lock actuators. All door lock and all door unlock. Vehicles equipped with keyless entry have three internal drivers in the BCM. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Nov 26, 2017 | Saturn Cars & Trucks
Door lock dont always work
What door lock doesn't always work ? One or all of them . This is a complex set up for these door locks ! The switch is an input to the BCM - body control module . There is logic involved in the microprocessor , there are relays built in to the BCM ! Could have a DTC - diagnostic trouble code stored in the BCM ! Could be a bad connection at the BCM or master window switch ! A bad ground !
DOOR LKS fuse
Driver door lock actuator
GMLAN serial data link
Keyless entry transmitter
Passenger door lock actuator
Passenger door lock switch
Remote control door lock receiver (RCDLR)
The DR LCK fuse supplies battery voltage to the body control module (BCM) for the power door lock system. The BCM supplies and monitors a reference voltage to the driver and passenger door lock switches through the door lock switch lock/unlock signal circuit. Each door lock switch receives ground at G300 which is also the ground for the door lock and unlock relays located in the BCM. When a door lock switch is placed in the lock position, the reference voltage is switched to ground and the BCM senses 0.0 volts on the door lock/unlock signal circuit. When a door lock switch is placed in the unlock position, the reference voltage is switched to ground through a 1.5k ohm resistor that is internal to each of the door lock switches and the BCM senses approximately 2.9 volts on the door lock/unlock signal circuit. The BCM interprets what position the activated door lock switch was placed in based on the voltage drop.
The BCM, upon receipt of a lock or unlock switch signal, will switch the appropriate door lock/unlock relay coil control circuit to ground causing the appropriate door lock/unlock relay to energize. With the relay energized, voltage is applied to the door lock actuator control circuit causing the door to either lock, or unlock depending on what command was received from the power door lock switch or remote control door lock receiver (RCDLR). When a power door lock/unlock relay is not energized, the switch contacts are normally grounded through the BCM which provides ground to the appropriate door lock actuator for the lock/unlock function being performed. The power door lock/unlock functions are performed by reversing the flow of voltage through the door lock actuator control circuits. The BCM has three internal drivers for the power door lock system. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked separately from the passenger door. For additional information concerning keyless entry, refer to Keyless Entry System Description and Operation.
This is one you may want to take to dealer or some other ASE certified repair shop ! To do this right you need a Tech 2 scan tool !
Ignition ON, observe the scan tool Door Lock Switch parameter while using the driver and passenger door lock switches. The parameter should change from Idle to Lock and Unlock.
If the value does not change, refer to Door Lock Switch Malfunction.
Command the doors to LOCK and UNLOCK with the scan tool, the door lock actuators should LOCK and UNLOCK when changing between the commanded states.
If one or more doors do not LOCK or UNLOCK, refer to Door Lock Malfunction.
Aug 12, 2015 | 2009 Pontiac Solstice Convertible
What causes a malfunction in power locks?
The power door locks are controlled by the BCM -body control module ! The door lock switch is an input to the BCM .
First thing to do would be check power an ground circuits at the BCM ! Do you have any other systems not working -power windows etc...
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
Should have BCM checked for stored DTC'S - diagnostic trouble codes !
Ignition ON, observe the scan tool Driver Door Lock Sw, Psgr Door Lock Sw, Driver Door Unlock Sw and Psgr Door Unlock Sw parameters while using the driver and passenger door lock switches. The parameters should change between Active and Inactive.
If the values does not change between the commanded states, refer to Door Lock Switch Malfunction.
Command the driver door and passenger door lock actuators to LOCK and UNLOCK with the scan tool, the doors should LOCK and UNLOCK when changing between commanded states.
If a door lock actuator does not perform the LOCK and UNLOCK functions, refer to Door Lock Malfunction
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
Aug 09, 2015 | 2010 Chevrolet Impala
Canon GL2 is not turning on. Switched battery and lock is off.
This is usually caused by a failed component in the power circuit within the camera and will require disassembly and trouble shooting to narrow down the cause. This can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 22, 2011 | Canon GL2 Mini DV Digital Camcorder
My GL2 will not power on. Nothing I have tried makes it work. I have tried everything, Standby/Lock switch, changed the memory battery. What is the 5 volt DC Terminal used for that is located above the...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Jan 23, 2011 | Canon GL2 Mini DV Digital Camcorder
Front driver door has no power, I have checked the fuses but no controls will work
This is a manufactures bulletin
SUBJECT:
Inoperative Right Front Door Switches OVERVIEW:
This bulletin involves replacing the right door interior handle. The loss of ALL functions may occur when attempting to control them from any of the switches located on the right door due to electrostatic discharge through the right door interior handle. The right door interior handle must be replaced to protect the switch module from static electricity. The new handle is more resistant to electrostatic discharge. MODELS:
2004 - 2008 (CS) Pacifica SYMPTOM/CONDITION:
The vehicle operator may experience a permanent loss in ability to actuate ALL of the following functions from the right door switches: ^ Power door locks. ^ Right power mirror. ^ Right power seat adjustments. ^ Right power window control. ^ Right heated mirrors. ^ Memory functions associated with the listed systems on right side (if applicable). ^ Loss of communication with the right door switch module to Scan Tool: DIAGNOSIS:
Perform a "Hard Reset of the right door switch module. This may be accomplished by removing all power (including memory keep alive power) from the right door switch module by unplugging the module power connector. Alternatively, vehicle power may be interrupted by removing the negative battery terminal when the ignition switch is in the OFF position. If after performing the hard reset functions of the right door switches return perform the Repair Procedure.
PARTS REQUIRED:
REPAIR PROCEDURE:
1. Disconnect the negative battery cable. 2. Remove the right door trim paneldak408_80.gif
3. Remove the door tweeter speaker. Refer to the service information in TechCONNECT. Refer to 8 - Electrical > Audio > Speaker > Removal (Fig 1). 4. Remove the power seat switch. Refer to the service information in TechCONNECT. Refer to 8 - Electrical > Power Seats > right Seat Switch > Removal. 5. Replace the right door interior handle, p/n 05170261AA, as described on Mopar Instruction Sheet K6855628 included in the handle kit. 6. Install the power seat switch. 7. Install the door tweeter speaker. 8. Install the right door trim panel. 9. Connect the negative battery cable.
Nov 25, 2010 | 2006 Chrysler Pacifica
Igniton key is stuck in switch and won't turn off
Check the shift cable to the shifter to the transmission,and the shifter could be malfunctioning.
May 16, 2010 | 2004 GMC Envoy
My Canon GL2 will not power on in Camera mode but it will in Play(VCR) mode. The lock switch in the back is not on lock I have gone bak and forth with the switch but still nothing. Any ideas?
Wow, ended up with the same problem tonight!!!! What a coincident.. So far I have found if I remove the clock battery, it boots every time.... hoping that all it is is that the clock battery is dead... wait have DVM right here...hmmmm.. 2.98V... but have turned camera on and off dozen times... still starting up....
Feb 06, 2010 | Canon GL2 Mini DV Digital Camcorder
Camera works in vcr mode but is dead in camera mode. why?
This happened to me once. I found that there is a switch on the back of the camera. It was accidentally moved to the locked position. Once I put the switch back to the standby position, it worked fine.
Jan 06, 2010 | Canon GL2 Mini DV Digital Camcorder
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Canon GL2 Mini DV Digital Camcorder Logo
548 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
