15 DAY OLD TV
CANT ACCESS MENU ALL I GET IS BLUE SCREEN WHEN I PUSH INFO BUTTON SAYS NOT AVAILABLE SAME RESULT WHEN MENU IS PUSHED
  • 2 more comments
  • majzun Feb 24, 2008
  • ultrinah Nov 14, 2008
    I have the same problem. My warranty is up. What to do?
  • Justin Hodorek
    Justin Hodorek May 11, 2010
    http://www.twenga.co.uk/offer/122005199....
    Is this your television?
  • Justin Hodorek
    make and model number? if it's 15 days old, call the place where you bought it or the manufacturer and ask them what's going on with it - you didn't provide enough info to help us figure out what's wrong.
Specifications Key Features Screen Size37 inch Contrast Ratio1,000:1 Flat Panel TypeLCD Television Display Resolution1366 x 768 pixels LCD Response Time8 ms Display Capabilities Built-in TunerNTSC · ATSC Broadcast Format Displayed480p (EDTV) · 720p (HDTV) · 480i (SDTV) Native Aspect Ratio16:9 Image Quality Brightness500 cd/m²
Posted on Feb 04, 2008
  • 113 Answers
Make sure you are hitting the right menu button. Samsung thinks they are dummy proofing their tvs. You cant get to anything they do not think is pertinent at the time. Make sure you are hitting the write button on the remote. Try to hit menu on the tv and see if that works.
My 32 inch element tv when i push the power button its red then turns blue but no picture
How old is it? TRY this.. Hold down the menu button on the top or side of your TV for at least 10-15 seconds. An on screen menu will appear asking you to enter the time, date and location settings. Follow the onscreen instrucitons, and once completed your TV will reset to factory settings.
Feb 02, 2017 | Element Televison & Video
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
Jul 12, 2012 | Polaroid Televison & Video
Projection TV flickering blue screen, cannot access devices
Did you ever get this problem solved. I am having the exact same problem?
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
How do i access the service menu of hitachi television. thanks!!!
F59 SERIES
* Press and hold the {MENU} button on the TV.
* Then press the {MENU} {8} {SELECT} buttons on the remote.
* To exit, press the {MENU} button on the TV or
the {EXIT} button on the remote control.
DCAM Mode:
* Using the remote control:
* Hold down the {TV} button.
* Press the {MENU} button.
* Press the {INFO} button.
* Release the {TV} button.
* Remote Control Key Functions When In DCAM Mode:
{INPUT} ............. Blue (13x9 adjust)
{ASPECT} ............ ROM Write
{DAY/NIGHT} ......... ROM Read
{MENU} .............. Remove Color
{EXIT} .............. Cross Hatch/Video Mode
{INFO} .............. Green
{GUIDE} ............. Calculation
{2} ................. Cursor UP
{5} ................. Cursor DOWN
{6} ................. Cursor RIGHT
{4} ................. Cursor LEFT
{0} ................. RED (7x5 Adjust)
{STOP} .............. Initialize
{PLAY} .............. Raster Position
{FAST FORWARD} ...... Phase
To Exit The DCAM Mode:
* Press and hold the {TV} button.
* Press the {0} button.
* Press the {1} button.
Oct 25, 2009 | Beko 142746 TV
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
LTV-40w1 HDC Westinghouse TV
I had the same issue. I just bought this tv. I went to source on the side of the tv pushed the input button til it went to YPbPr1 and the screen came up. My HD cable box is a little old so I'm using that instead of HDMI. But if your using HDMI just keep hitting that button til you see HDMI and it should work.
Sep 19, 2007 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
