Question about HP Compaq Presario v3000z Notebook
Laptop stopped functioning
It has stopped functioning at once & is showing Err2Err3 on the screen
    President:
  • 2,351 Answers
Some companies like to put a small partition located at the beginning of the drive. It's around 4Mb. Just small enough for you not to be able to install another operating system. (nice uh).
Bottom line something went wrong on the hard drive. So put your system restore CD in your cdrom & start up the notebook. What you want is to repair the operating system. If you try to do a restore you might be able to go out & see a movie. And there is a good chance it will fail. Here is the link to your notebook:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3179587&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=321957&prodSeriesId=1817055
Please post back if this did not help & well take this on from another angel!
please vote...
Posted on Feb 04, 2008
Hdd 2tb only showing in device & printers
Sounds like you require new drivers for the USB sockets. Only use Acer drivers, Microsoft are not trusted to work without issue.
Acer Explore Beyond Limits
Aug 30, 2016 | Acer Aspire V5-571P-6835 15.6" Touch...
I have connected my hp Pavilion dv6 to my panasonic p46v20z but no picture shows on tv. Is my pc not compatible?
Usually there is a key on the keyboard that must be pressed with the function key to alternate the video outputs. Usually it is Function F7 or F8. This key set must be pressed more than once to get the preferred setting. Each time it is pressed you will get one of the following. Out VGA, Out VGA and Monitor Screen, and only Monitor Screen.
Monitor Screen being the laptops display screen. Out VGA being the rear port on the laptop.
This is usually the reason for the issue you are having.
Jan 29, 2013 | Computers & Internet
Having problems getting my powerpoint slide to show from the laptop onto the screen. Not sure what the function key is?
try Fn key with F5 or F8. depends on your model of laptop.
Look for the screen symbol on one of the function keys and try pressing that once and wait several seconds to see the screen changing video. Then press again if not correct.
If nothing is appearing on the projector, then connect a lcd monitor on the laptop and try the function keys intil it works thyen swap the monitor for the projector, and start the input scan for the active video input.
Mar 31, 2011 | Sharp Notevision XG-P10XU Multimedia...
I accidently disabled the screen on my laptop its a windows xp. when i turn it on i cant see anything but i can hear it how do i get it to work again without having to erase my stuff in the laptop?
Lookv for a function key that shows an external monitor and a laptop, I hsave a Toshiba and mine uses the F5 key. Hold down the Fn key and tap the appropriate Function key. This might need to be done more than once to cycle through to the LCD, but eventually the screen should come back to life for you.
Apr 13, 2010 | Dell Inspiron 9400 Notebook
I get a err2err3 when i boot up on HP/windows vista
i think your vista boot dvd is corrupted .just try with another one.i mean your dvd is just sort of malfunctioned because of may be more scratches.
if find useful please rate this
Feb 22, 2010 | HP Pavilion dv9000z Notebook
How do i get my laptop screen to show on my tv? I have my laptop hooked to my tv with a VGA cable and my tv input is on vga, nothing comes on just blank screen
Most laptops have some key or combination of keys you need to push to tell the laptop to send the image to the alternate screen (VGA out). On Dell laptops it's often the F8 key. Pushing this key multiple times will typically toggle the output between your laptop screen, the VGA output and both at once. I hope this helps you out.
Dec 30, 2009 | Televison & Video
Laptop projector problem...
To get the laptop screen to show on the projector press function F5
if you want the screen to show on both press funtion f5 once more
Have a great day!
Jan 29, 2009 | Acer Aspire 5100 Notebook
Hooking-up a new monitor to my laptop
Find the connector on your laptop that matches your new laptop. Plug it in and let Windows discover it....
It probably will say something like "found new hardware" and will install a "generic" driver for your new monitor. After the driver is installed (and Windows should tell you that the device is ready to use", Find the row of keys known as function keys. Usually, all function keys on the top row have a second set of symbols on the "f1 through f12 keys. You should see one the looks like "lcd" which refers to the monitor on your laptop and the other that shows a rectangular symbol with an arrow indicating out to an external monitor. Once you hold the function key down and press whatever key shows the symbol, the laptop image will switch to the new monitor. To switch back to the laptop screen, reverse the process. Thanks for using Fixya.com.
Jan 27, 2009 | Computers & Internet
Not opening my laptop
Here's what you need to do to fix it: Find some way to get Partition Table Doctor (http://www.ptdd.com/download.htm) and put it on either a live boot CD or from a secondary hard drive installation. Once you have that, Scan the partition for errors and select fix boot... Then if you're running Vista get a copy of Vista Recovery Disc (http://blogs.techrepublic.com.com/window... burn yourself a copy of the disc, and run it at the boot of your computer. Once the cd is loaded, click on REPAIR WINDOWS, select COMMAND PROMPT, then use this command: bootrec.exe /fixboot
If that doesn't work use: bootrec.exe /rebuildbcd
and see if your windows boots.
IF you have windows XP, boot up with the Windows XP cd, select Repair (R), go into the command prompt (selecting which windows installation you want to modify) and then type this command: fixboot c:
See if your computer boots now.... The important thing is to try to repair your boot which has been deleted or corrupted, that is why it gives the error: err2err3
Try different recovery tools like Table Doctor http://www.ptdd.com/ in conjunction with your recovery cds (windows xp installation CD and Windows Vista Recovery Disc)
Jul 17, 2008 | HP Compaq Presario v3000z Notebook
HP Compaq Presario v3000z Notebook Logo
523 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
