Question about Toshiba 27D46 27" TV
Got sound and no picture.
I got this from someone who told me the picture went out but there is sound. I transported this tv to my house plug it it and it displayed a picture with sound. when i went to replug it , again no picture... please help.
Ron
Ron.Negron@hotmail.com
718-419-9111
    Brigadier General:
  • 6,966 Answers
It would seem that there is a loose connection or even perhaps a cold solder internally.
What needs to be done is to open the back of the unit start checking the multiple connectors to the PCB. Unfortunately this has to be done with the unit live and with the use of a mirror to be able to determine in which area/section that the picture will be restore. You would need of a bit of insulated rod about 1 to 1 1/2 feet long to move the wires and push a little on the connectors (a broken fiberglass fishing rod would be perfect). Determining which one is pretty straight forward. Correcting is simply inserting the erring connector more firmly to the socket/mate.
Cold Solder is done very much the same way but rather than wires and connectors, you would need to push on the terminals/leads/pins of the components. Alternately, you can turn the PCB board over and with the use of a strong light and a magnifying glass, visually inspect the solder joints. More often cold solder develops on high powered components such as high wattage resistors, diodes, transistors, regulators. Corrective measure would be re-applying heat through a soldering iron.
Both the above requires familiarity with electronic circuits and components, use of a DVM and a soldering iron. If you are comfortable, you may need to seek the services of a qualified professional.
hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Posted on Feb 04, 2008
KP61S75 has 45* angled stripes.
1? you must test the power supply, the absence of this cause a LOT of problem, test a= fuse, filter, c.breaker rectifier.
2) test the tuner, i-f, video detector, AGC, section
3) if the tv has external POT adjustment for vertical, horizon, do it carefully.
4) tight any wires connector loose, or bad contacts.
God bless you
see the diagram
Jul 18, 2012 | Sony KP-61S75 TV
No sound, no picture
Hello sorry to hear that. From your description it sounds like your signal board may have been damaged by you plugging in your laptop to it. The signal board is the one with the tuner on it.
Feb 22, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
Had a power surge through my house tv picture went out I think there is still sound but no picture anysuggestions
make sure to plug in all major electronics and appliances to a very nice surge protector. If you have tried the TV in other outlets that you know work, and it doesnt display anything. It is probably power supply.
Sep 17, 2010 | Digimate DGL32 32 in. LCD Television
Sound working no picture
Depending on the events leading up to what happend...
Was your plasma tv recently transported or moved from one area to another?
One thing about plasma tv's if you lay them horizontally or has been tilt at a certain angle they will have problems projecting any picture. PLASMA tv's should ALWAYS stay vertically standing. you can let it stand where it should be for atleast 24 hours ( i recommend upto 48 hours) without plugging it in.. (no electricity what so ever) then check if it works.
About the click you heard, it might have been a blown fuse. Probably resulting from plugging in the tv while it was in a "chemical inbalance". therefore my above recommendation is a bit too late. if you still have warranty then you have no problem. just the hassle.
Mar 01, 2009 | LG 42LC2D 42 in. LCD HDTV
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
Picture Was Getting Slightly Dark For 2 Days, Now Nothing But Flashing Red Light
It sounds like your lamp finally went out.
you might want to have someone check, just to make sure.
Aug 01, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Follow up on "no power to my tv"
3d picture ...sounds like to me a convergence amp issue...what type of tv is this?
Dec 01, 2007 | Televison & Video
Sounds like it. Replacement of both STKs is required. (They should always replaced as a set).
May 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 27D46 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
