Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV34-HS510 when you try to power TV up all you get is a click click click sound
  • doorman45 Feb 04, 2008
    is there one ic that has a history for causing this to happen
  • acat Mar 07, 2008
    Thank you I belong to circuit works and I think that you are right...
    How do you go into service mode???
    Craig
    Problem Solver:
  • 15 Answers
Tv is in protection mode...first u most measure psu output, next horizontal transistor driver, and all outupts from flyback....and find witch one is in fault
Posted on Feb 04, 2008
My sony tv 34 inches model kv34*90 become colors yellow
Hello
Just mention the full model number of your Sony TV. There will be some more letters follow [KV34-----]. Send it clearly to me by Fixya. Even though it is 34" TV, these suffixes are important for trouble shooting.OK.
Mar 06, 2011 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
I have a 2004 Sony Wega Trinitron KV-HS510 that will not turn on. When I try to turn on the TV it sounds like it will power up and then I hear a click, and the TV turns itself off. The Stand By Light is...
7X blink is a generic Horizontal Deflection Stop code. There is a chip in the TV, IC8005 or 8006 if I'm correct, that routinely goes bad on these sets. It could be one of any number of transistors or IC's, but that one is usually the culprit.
The chip itself is around 40 dollars, and with labor, you're looking at about 125-175 average, barring any unforseen problems. That's in-shop. Tack on a service call charge if it is in-home (if anyone will do that for you).
Hope this helps you...
Jan 07, 2009 | Televison & Video
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony trinitronKV34-HS510 3 blink code
i dont think its HV
3 blinks is B+ voltage.
just replace the main board.
sum times andrews electronics has them for around $80
regards,
daniel.
Feb 05, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV34-HS510
TV's always make a clicking sound as the Main Power relay turns on. If you are asking why it then doesn't turn on, it can be many things. The processor monitors a number of circuits and if something is amiss, it turns off. The most common failure is the high-voltage circuit and if the set is any where near 10 years old, I'd plan on replacing the flyback transformer as well as anything else it damaged while failing.
Another option is to wholesale replace the main board from an outfit like PTS Electronics at ptscorp.com.
Hope Ya Fix It!
Feb 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Clicking noise sony bravia kdl-40v3000
Normal 0 My kdl-46v4100 has been off all day and I've heard two or three clicks. It sounds exactly like the click you hear when it’s been off all day and you go to turn it on. A few minuets after it clicked I turned it on and to my surprise there was NO click sound.
This LCD TV (like most large displays) uses an Active Matrix of thin film transistors, aka TFT. Essentially the screen is a large array of transistors and capacitors. According to my previous observations; I suspect the random clicks are associated with the LCD circuitry providing a fresh “standby charge” to the TFT array (hence no click on power on following a “refresh”).
Not a solution, but an explanation other than “cooling off…”
Nov 29, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
