Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
DVI input When utilizing the DVI input my Mitsubishi WS55315 will not display the entire desk top, game screen, ect.... To get a stable viewing from the DVI input the TV must be set for a VERY LOW resolution, i am comfortable with this but regardles of the resolution i choose i loose lots of the screen, much of it is viewable, but not all. Can this be fixed?
  • 1,554 Answers
Normal desktop settings for a laptop to tv is 1024x768 60hz refresh.
Posted on Feb 04, 2008
PC DVI-D to Mitsubshi DVI-I no signal
have you set the dvi out to 720i as any higher the tv will not read it as a signal. you will need to verify it in properties windows will set it at 1080i. you need to change it.
Mar 08, 2014 | Mitsubishi Televison & Video
Hdmi screen format problems
try it on av tv it may view and explain briefly i cant understand
Dec 08, 2007 | Denon AVR-3806 Receiver
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
Mitsubishi WS55315 rear-projection has gone dark
Yes, they have other than convergence circuit problems----very few issues or troubles.
You should test the shops by asking if they have the 4 digit code number for this model for the OPTION MENU---set has 3 hidden menus and OPTION menu will allow a hard reset of entire set---the other two menus are adjustment and convergence menus.
If some shop has no idea what the option menu is----pass them.
Mar 24, 2012 | Mitsubishi WS-65315 65" Rear Projection...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How can I connect my Desktop computer to my Hitachi 57F500 TV? I have an emachines desktop, running MS Win 7 connected from Monitor VGA port to DVI port on TV via Dynex DVI-VGA cable, but not getting any...
VGA and DVI are not compactable. Your TV has no provision to connect it to computer.
DVI-HDTV Input (Input 1)
Use this DVI-HDTV Input for your external devices with DVI-HDTV output such as a Set-Top-Box, high-band DTV decoders, DVD
players and D-VHS with Digital Content Protection
1. Only DTV format such as 1080i, 720p, 480i and 480p are available for DVI-HDTV input.
2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer.
3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed
on the screen in its digital form
Mar 23, 2011 | Hitachi 57F500 57" Rear Projection...
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Jul 04, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Ps3 hdmi to dvi on mitsubishi wd52327
What brand DVI connector and how many pins are on the connector. try a different cable
Dec 25, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
