Question about Avery DesignPro Deluxe CD-ROM Label-Printing Software (50072782052398)
Avery Ink Jet Magnetic Sheets - 3270
Although the Avery magnetic paper I am trying to use says it is designed for ink jet printers (HP included) the magnetic paper will not feed through my my HP Photosmart C5180 printer. If I put one sheet in, it just kicks it on through and prints my project on regular paper. If I put two magnetic sheets in it says it's out of paper. I've never had problems printing anything before. This is frustrating, especially since the package says and I quote "It's Easy! ...
Guaranteed to feed easily through Cannon, Epson, HP and other ink jet printers." It also says it works with Word.. Uhh, not for me it doesn't. Avery 3270 is not one of the built in Avery templates in Word. I tried to find a template from Avery to download online, but while the searchable Avery site recognizes 3270 as "Magnet Paper," it says it has no template to download. I think I need some help, cause I be stuck!
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Posted on Dec 29, 2008
Printer show paper jamed without paper in it
There's a small piece of paper on the sensor. 4 in 1 Cleaning Paper for Laser Ink Jet Printers 12 Pack Perfect Data PD... You need paper path cleaning sheets like tho ones here. That should clear the jammed condition.
Aug 12, 2016 | hp deskjet 3600 series
New black ink not drying on photos. Ink runs
Most likely you're using the wrong photo paper. Ink-jet photo paper is specially designed to absorb the ink, while copier paper isn't.
Sep 02, 2014 | Canon Pixma Mg5320 All-in-one Printer...
Can I print transparencies from my Canon iP1800
Transparency can only be printed by a laser jet. from a ink jet the ink will come off. you can try a photo copy machine that will work for sure
May 07, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Bad streaking on print xerox 8550 phaser tried the troubleshooting feature/eliminate light stripes with no luck
The best way to tell if your problem is clogged jets, or bad maintenance kit, or something blocking jets. Is to look at light stripes test, and see if missing jets are all in a straight row or all over the place. If the missing jets number less that 10 you can use jet substitution to avoid the streaks. If you are using Media Sciences or some other after market ink, check that most of your problems are not in the cyan area. Media Sciences produced a bad batch of cyan which clogged the jets pretty bad. The good news is that if their ink caused the problem they will pay for some one to come out and replace your printhead. If you LST (Light stripes test) has a smear the entire vertical lenght of the page. You have either a bad maintenance kit, or a piece of paper, lable etc..rubbing against the drum while printing
Jun 04, 2009 | Xerox PHASER 8550 COLOR Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp G85xi ink jet printer. Keep getting the
Possible your printer is equiped with by optical sensor of the determination to density of the paper. If he was littered by dust, that you it is necessary to clean his(its) compressed by air.
Mar 06, 2009 | HP G85xi All-Color InkJet Printer
Ink not dry when printing photographs
Download the proper drivers from hp.com - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
Nov 27, 2008 | Office Equipment & Supplies
Computers & Internet Logo
824 people viewed this question
Top Avery Computers & Internet Experts
Donna Sander
Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
