Question about Fisher and Paykel GWL11 Top Load Washer
Tub My tub pulls to the left is there another cord like the red cord on the left that should be on the rightside?
  • 125 Answers
No, there is just the one spring on the left side. try leveling the machine. Put the level on the bottom of the top deck where it meets the sheet metal, as the top deck is curved, that should solve the problem.
Posted on Feb 23, 2008
Pacifica Marquis Hot tub serial/model number TH-Y105113 power cord from wall to hot tub
Hopefully you've found your cord by now if not let me know and i'll point you in the right direction.
Sep 30, 2013 | Pool & Spa
The code error is LD
LD Error - indicates that drain times are longer than expected.
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller. If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (control board). This unit will have to be replaced.
Other details could find in this article HERE. Hope helps.
Oct 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
120v hot tub wiring diagram! Need to wire fro 120v! there is a red, white, black & green to connect the wire from the power plug. The power cord only has black, white & green. Which is the hot and...
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
May 15, 2010 | Pool & Spa
We have a GE front load washer WCVH6800. Recently we loaded some throw rugs into the washer. These rugs released a large amount of material. We cleaned the pump filter 3 times and it now seems clean. ...
The water inside the tub will drain out when the pump filter is removed from the pump housing and flood the base of the washer. If not, the tub drain hose is clogged preventing the water to drain into the pump housing then out.
The door is locked because the foam switch in the pressure switch is open due to the presence of water after the unsuccessful drain cycle.
Disconnect the washer from the power outlet. Remove the three screws holding the lower front access panel to the cabinet and pull the panel down to access the pump housing.
Squeeze the clamp that hold the tub drain hose to the pump housing and slide it back. Prepare a pan to catch the water to prevent flooding. The tub drain hose maybe difficult to remove and you may need to insert something under it to break the seal and pull it off.
Remove the tub drain hose from the tub by squeezing the securing clamp and pulling it off the tub drain outlet. Clear the hose and the tub drain outlet from any debris.
Reinstall the tub drain hose and manually unlock the door before reinstalling the access panel. Reach and pull the release ring behind and up the right side of the front panel, then open the door.
Feb 14, 2010 | Dryers
The water will not stop filling up.It never start to wash.
Hi, This will be one of two problems. Either the pressure switch is bad or the valve is stuck open. The way to figure which is: when the tub is filling pull the power cord out. If when pulling the power cord out the water stops it means the pressure switch is bad. The pressure switch can be located inside the control panel. It has 2 wires and a plastic tube sticking into it and is attached to the water level knob. If the water fails to switch off when you pull the power cord this means the valve is stuck open so you should replace the valve. This is located behind the machine and are what the hoses attach to. If you have any other questions please feel free to comment. Mike
Dec 10, 2009 | GE WBSR3140DW Top Load Washer
The spring on the tub of my Fisher and Paykel came disconnected
THE SPRING GETS CONNECTED FROM THE LEFT FRONT STRUT TO THE OUTER TUB COVER BY WAY OF A RED BIAS CLIP.
Apr 07, 2009 | Fisher Paykel EcoSmart GWL15
My hotpoint washing machine doesn't stop filling up with water
remove front cover by sliding putty knife along top edge and pressing down on clips pull front off ck small hose attached to tub on left side look for a dark build up in tube pull off and clean..blockage will cause water level switch not to sense full tub of water..if tub just never fill ck drain hose for correct height from floor and loose fit in standpipe
Dec 22, 2008 | Washing Machines
The tub @ my Fisher&Paykel model #GWL-08-US1 is off balance
you can lift the top and get a closer l;ook, by opening lid and looking approx, 4 inches back along side rail, youll see a rubber plug, remove the plugs toreveal the screws hoding down the main top. after emoving screw lift the top back and you see the 4 suspension bars tha hold the machine, either one "popped" or the left front corner should have a sdpring attached form it to the tub( clips on to the red little bracket on side of outer tub). either of thesse swill fixyour problem
Dec 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Good power, tub will not turn
tub, is the lid switch plugged in? If not take a jumper wire and jump out the two ends on the harness. Timer controls recirculation and spin. The motor turns both ways. The spin cycle goes through the lid switch. Catriver..post back
Feb 27, 2007 | Whirlpool LSQ8000 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
