Question about Samsung SPN4235 42 in. Plasma HDTV
Picture in Picture
Everytime I hit the PIP button I get a message stating "Not available in this current mode"
    Master:
    Sergeant:
  • 440 Answers
Cuse it only avb on these with seprate source ok llike dvd in one pip other tv ok not tv tv ok thx for using fix ya thx nick
Posted on Feb 04, 2008
Only getting a small picture in left hand corner of screen
It sounds like you might be in the PIP mode. check your remote for the PIP (Picture in Picture) and go hit it several times the picture should move around on the screen one of them should be the OFF.
Sep 22, 2014 | Televison & Video
My vizio flat screen has screen stuck in top right
Your TV is in Picture in Picture (PiP) mode. The small picture is the previous live input. The bigger dark area is the current input where there's no live source.
Find the PiP button on the TV remote or via the TV's menus. Press PiP a number of times to cycle through the options. Stop when the picture is the size you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 02, 2014 | Televison & Video
My grandson got hold of the tv remote and turned the pip feature on. we cannot turn it off. help!
Hey there..I had a PIP problem for the last 6 weeks and just solved it with this tip. The solution was in front of me all the time.
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you
Dec 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I have a hitachi tv model # 51f59, the picture and sound are fine, my problem is that in the upper right corner the PIP is on, no matter what i do I can not get it to go off, I have hit the PIP button...
hello Press the PAUSE button to freeze the picture you
are currently viewing (only the right sub-picture will
freeze). Press the EXIT button to return to normal
viewing. Please refer to page 27 for detailed spec. if this don't work i'll send you the manual for free get back to me i'll send you my email address thanks
shaun
Oct 25, 2009 | Hitachi 51F59 51" HDTV Projection...
Can't turn off PIP on Sony XBR videoscope TV
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Televison & Video
Tiny picture
try hitting the PIP button on the remote, sounds like it is in PIP mode, and the vizios have many configurations of PIP
Mar 19, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
KP53V75
you do NOT need to buy the original remote!! press the setup button on the front of the tv, then you will see a menu and you want to select auto set up by pressing the volume minus button and then the tv will automatically start to scan for channels and pip will be gone! Pain in the booty but save you from buying original remote!!
Feb 23, 2008 | Televison & Video
Turning OFF picture in picture!
I have an old Sony Trinitron; had the same problem... somehow turned on the pip while moving the television off its stand. I have neither the remote nor the manual.
Does your tv have a 'demo' button on the front? Mine does; when I pressed it, the pip disappeared!
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture in Picture Issue
hit the pip button again it should shut it off
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Samsung SPN4235 42 in. Plasma HDTV Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
