Question about NEC PlasmaSync 42MP3 42 in. Television
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
IT JUST TURNED OFF ONE DAY.THEN WHEN I TRY TO TURN ON THE GREEN LIGHT GOES TO STANDYBY MODE AND BEGINS TO BLINK RED ..ANY SUGGESTIONS ON WHAT THE PROBLEM COULD BE ? THANK YOU
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Posted on Mar 01, 2008
Where is the ysus board located on a nec plasma sync 42mp2(px-42vm2a) tv.
The board is located on the extreme-right at the center of the chassis. In some sets I have seen the Y-sus on the left and the Z-sus on the right. If you can get me the part number off the board I can confirm if that is the board
May 21, 2011 | NEC PlasmaSync PX-42VM2A Television
My nec plasma tv seems to turn on for a few secconds then returns to standby,I took the back of it and tested fuses. 2 hi temp ceramic fuses were blown 4Amp any ideas?
Have you tried pressing the "Input select/Exit" button? Right after pressing the power button and the light turns green, press this button until you get to the right input that you are connected to, and hopefully you should see your picture. I had this same issue when I first got this T.V., Hopefully this helps!
Jan 25, 2010 | NEC PlasmaSync 42MP2 42 in. Television
I have 42 nec plasma when i turn on work normaly but after seconds picture became dark
Have you tried changing the input? Meaning, as soon as you power the screen on, press the "input select" button then wait a few seconds if nothing comes up press it again, do this until you find your connection and you should be set. This problem seems to keep coming up with this particular Plasma, so I guess I'll keep on answering. Good Luck
Jan 06, 2010 | NEC PlasmaSync 42MP2 42 in. Television
My 43" plasma tv wont turn on. I unplug the unit and plug it back in then try to tur it on. The light turns green as if it is going to turn on then you hear a click from inside the unit and it never comes...
Your power supply or high voltage transformer is shot. Both are extremely common especially in newer devices. You can test with an ohmmeter to find the faulty component or capacitor. The capacitors in the power supply overheat, swell up, and burn out You can get parts and manual from shopjimmy.com
Oct 11, 2009 | NEC PlasmaSync 42MP2 42 in. Television
I have nec plasma sync 42mp2 but no remote
Usually many plasma's have their controls on the side of the screen including power, so I would check their 1st.
As for getting a remote, harmony (now owned by logitech) makes some great remotes. One of the advantage of their remotes is that they are programmed from the computer by entering the model # of the items you wish to control. So you would just enter the NEC model to program the tv.
May 12, 2009 | NEC PlasmaSync 42MP2 42 in. Television
NEC plasma sync 42mp2 vm2g
If your referring ot an outside antenna or cable, your set does not have a tuner, it is a monitor style. You will have to get a converter box and use the video input ( yellow) (red/wht-audio) on the tv, or the component input ( green, blue, red ) on the tv, provided, the box has the output for it. Most cable boxes have these and the antenna dtv converter boxes do not as far as I know but look into it.
Dec 27, 2008 | NEC PlasmaSync 42MP2 42 in. Television
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Help
Same problem here. PX-42VM2A (NEC PlasmaSync 42MP2) Turns on (status light green) then goes to standby mode (status light red) after what sounds like some electrical relays clicking over. Opened it up and no glaringly obvious problem, but i'm no components technician so... Any ideas? Anyone want to buy it for parts or need a specific part? email me: 318noire<at>gmail<dot>com
Oct 13, 2007 | NEC PlasmaSync PX-42VM2A Television
Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Dec 14, 2006 | NEC PlasmaSync 50MP1 50 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
347 people viewed this question
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
