Question about D-Link DI-634M Wireless Router (DI634M)
Error 503 service unavailable
When I type in the ip adress for the router 192.168.0.1 I get an error message "503 service unavailable" after trying over and over I finally reached the login page, but when I logged in it said "the network is down" even though the network is working fine. This has never happened to me before.
  • Anonymous Jan 29, 2009
    503 service unavailable DI 634M
  • Anonymous Feb 05, 2009
    How to check router is working properly?
    Problem Solver:
  • 19 Answers
Theres something wrong with your router; try to check if the router is working.
Posted on Feb 04, 2008
My ip adress says unavailable
Sounds like the computer you're trying to connect to your wi-fi router is set up with a static IP address that is being reserved by your router for DHCP. To resolve, make sure your router has "DHCP" (dynamic host configuration protocol) turned on. Make sure the computer you're trying to connect to your router is set up to allow the DHCP server in your router to set the computer's IP address and DNS server address. You can find instructions to enable DHCP in your router's user manual or by searching online. You can find instructions for setting your computer's wireless adapter to allow the DHCP server in your router to set the computer's IP and DNS addresses here:
http://www2.wolfson.cam.ac.uk/files/IT/Settings_for_DHCP_for_Windows.pdf
Jan 07, 2014 | Computers & Internet
Am using small business server 2011and and it says http error service unavailable
Hi sebenzile,
The Web server (running the Web site) is currently unable to handle the HTTP request due to a temporary overloading or maintenance of the server. The implication is that this is a temporary condition which will be alleviated after some delay. Some servers in this state may also simply refuse the socket connection, in which case a different error may be generated because the socket creation timed out.
Any client (e.g. your Web browse) goes through the following cycle when it communicates with the Web server:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognizes as '503'.
Basically, the Web server is effectively 'closed for repair'. It is still functioning minimally because it can at least respond with a 503 status code, but full service is impossible i.e. the Web site is simply unavailable. There are a myriad possible reasons for this, but generally it is because of some human intervention by the operators of the Web server machine. You can usually expect that someone is working on the problem, and normal service will resume as soon as possible.
You can also contact the system operators of the Web site (e.g. your ISP) to determine why the service is down. They will be in a much better position to help you than I am for this type of error.
Sorry so long winded:)
Hope this helps!
And please rate
Thanks,
Gary
Aug 27, 2013 | Computers & Internet
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Unable to connect to my ip address 192.168.0.1 error message reads ip address is there but not responding
could you tell me the Router model number to find the right Ip adress of your Router go to start the run type cmd press enter and the type ipconfig press enter if you get default gateway 192.168.0.1 then you can connect to it also ping it and see if u get reply if need help please contact me on http://computernetworksupportindubai.com/
Jul 22, 2011 | Computers & Internet
I type in my email address and i always get 503 error unavailable how do i fix the problem???
what is the model and the model number of the router that you have? Also did you try resetting the rrouter from the back? Most routers have a small hole in the back of them, just use a paper clip and hold it down for 30 seconds and that will reset the router back to the default factory state.
Jun 12, 2011 | Computers & Internet
Http://503 error in exchange mail
Try this if it doesn't work tell me and I will continue troubleshooting
After you type the address to Microsoft Outlook Web Access (OWA) on an Exchange 2003 computer, you may receive the following error message on your browser before you receive the OWA log on prompt: 503 Service Unavailable
This problem occurs if the Davex.dll file cannot communicate with either a mailbox store or a public folder store.
Make Sure That All the Services Are Running
The "503 Service Unavailable" error message may occur if the Exchange 2003 services are not running, particularly if the system attendant and the information store are not running. To view the services and make sure that all the services are running!!
Ryan Frame
Creative Energy Associates Technical Center
Apr 27, 2009 | Microsoft Windows Server Standard 2003 for...
How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
I assume you know the ip adress of your xbox.
First of all check on your router to see if UPNP is enabled.
Then go to Portforwarding/Port triggering.
Then add custom service
service name: the name of how you call it. doesn't matter really
service type is UDP
start port 88
end port 88
server ip is the adress of your xbox
then apply and make another custom service
name it how you want
service type tcp/udp
start port 3074
end port 3074
server ip adress of you xbox
this should work
Jan 03, 2009 | NetGear WGR614 Wireless Router
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
you need to activate this services from ur service provider..
Jan 05, 2008 | HP Pavilion dv4000 Notebook
D-Link DI-634M Wireless Router (DI634M) Logo
579 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
