Question about InFocus IN72 Multimedia Projector
IN72 psychedelic traces
Watching a scene with people moving across a dark background, there are traces following movement.
Rather than streaks, it is a series of ghost images or echoes of the movement that linger on the screen.
Anyone see this before?
  • 1 more comment
  • goodconsumer Feb 05, 2008
    A moving box would look like this
  • wadell Feb 13, 2008
    But did replacing the bulb solve the problem for rickrickie?
  • mherbster Mar 03, 2009
    I have the same problem and was wondering if replacing the bulb solved the problem? If it is the bulb would I have other distortions or would I have other issues that would pin point the bulb as the problem?
    Problem Solver:
  • 17 Answers
Have the same problem took mine apart for cleaning and inspected the bulb looks like bubbles in the bulb that will hold disorted images on the screen so im going to replace bulb
Posted on Feb 09, 2008
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Got a couple of dark streaks on my flat screen. More prominent in extreme dark scenes and light scenes
    you will want to go into your tvs setting and restore factory defaults using the user manual if after doing this your still getting the dark streaks the television may need a new board. The cost of a new board and labor is usually cheaper than buying a new tv but if its still under warranty or you still have the receipt I would suggest returning it to avoid the headache
    Robb
    Sep 27, 2010 | JVC Televison & Video
    How do you take a picture of a fast movement?
    It depends on the effect you want.
    • To freeze motion, you need either a fast shutter speed, or a fast flash in a dark environment. In less than bright light you may not be able to get a fast enough shutter speed to stop the action. Increasing the camera's sensitivity to light by increasing the ISO will help some.
    • You can blur the motion by using a slower shutter speed and a stable camera. Set a slow shutter speed and put the camera on a tripod or other stable surface, and you can get things like streaking car taillights and star trails. How slow a shutter speed depends on the speed of the subject.
    • You can pan with the subject. Move the camera with the subject, and keep it moving even while the display blanks out while taking the picture. This will keep the subject sharper while blurring the background to lend a sense of motion to the picture.
    • It's either to freeze motion if the subject is moving straight toward or away from you than if it's moving across your field of vision.
    Sep 10, 2010 | Canon PowerShot S2 IS Digital Camera
    Red rash that shows through in dark scenes. Can't
    Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
    Dec 20, 2009 | Toshiba 50HP66 50 in. Plasma Television
    Copies too dark
    Hi Scottie,
    Please clarify if the darkness is like a darkened background or like streaks across the page... If it is the former you will just require a clean of the optics, if the later then a drum cleaning blade will probably do the trick...
    Please let me know if I can help further johno@execs.com .
    Oct 25, 2009 | Copystar CS-2114 Copier
    Pink pixels across plasma screen.
    I have the something going on w/mine!!! Are your fans turning on?Mine are not.I think that's my problem...Get back w/me..thanks,jon.
    Dec 23, 2006 | Pioneer PureVision PDP-503CMX 50 in....
    Exposure control options
    The following exposure options are available: P (Program auto), A (Aperture priority), S (Shutter priority), and M (Manual). There are four scene programs modes available in which the camera will choose the optimal settings for the picture: Landscape: Suitable for taking photos of landscapes and other outdoor scenes. Both the foreground and the background are in focus. Since blues and greens are reproduced vividly in this mode, the landscape mode is excellent for shooting natural scenery. Portrait: Suitable for shooting a portrait-style image of a person. This mode features an in-focus subject against a blurred background. Sports: Suitable for capturing fast-moving action such as sports scene or moving vehicles without blurring. Night scene: Suitable for taking night scene photos with a slower shutter speed.
    Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
    The following exposure options are available: P (Program auto), A (Aperture priority), S (Shutter priority), and M (Manual). There are five scene programs modes available in which the camera will choose the optimal settings for the picture: - Landscape + Portrait: Suitable for taking photos of both you subject and background. The picture is taken with the background as well as the subject in the foreground in focus. - Landscape: Suitable for taking photos of landscapes and other outdoor scenes. Both the foreground and the background are in focus. Since blues and greens are reproduced vividly in this mode, the landscape mode is excellent for shooting natural scenery. - Portrait: Suitable for shooting a portrait-style image of a person. This mode features an in-focus subject against a blurred background. - Sports: Suitable for capturing fast-moving action such as sports scene or moving vehicles without blurring. - Night scene: Suitable for taking night scene photos with a slower shutter speed.
    Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
    InFocus IN72 Multimedia Projector Logo
    118 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
