Question about Kenwood KDC-MP632 CD Player
Everything working fine, no LCD display - Kenwood KDC-MP632 CD Player
    Master:
    Sergeant:
  • 440 Answers
Is lcd wires pluged in illumence
Posted on Feb 04, 2008
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
My display is either all black or all white. When an external monitor is attached, the display does work on the external monitor. Everything else works just fine when the external monitor is pluged inn
It's either the lcd itself the the lcd cable has become loose, either way you're going to need to take the lcd housing apart to make sure the cable is nice and secure (both ends - 1 to lcd itself, 2 to motherboard)
If the cable is nice and tight and you get the same results then for sure the lcd needs to be swapped out.
Oct 29, 2010 | Toshiba Satellite A305D-S6848 Notebook
Hp pavilion dv4 screen will not work. everything
Few trouble shoot solution when it comes to these HP Laptop from 08-09.
1). Remove battery and ram. Plug in AC Adapter and insert only ONE RAM into a slot. Boot up and see if this will turn on display (it work on a HP Dv4-1225dx) IF it works then shut down and re insert the two ram and should be good to go :)
2). If your tech savvy remove keyboard and gain access to LCD flex ribbon cable to check if cable is loose (or go on a limb and replace the lcd flex cable ). I would detach it and re attach the ribbon back to motherboard. ( This happen sometimes by chance)
3). Your LCD is shot dead so it will need to be replaced. Current used LCD can range from $40-$50 and new ones with warranty $60-$100. HP is set up for easy LCD removal so shouldn't take more then 30mins to replace, just be careful when handling the ribbon and inverter cables.
GOOD LUCK
(Fix many HP Laptop for friends and family)
Apr 04, 2010 | HP Computers & Internet
DISPLAY NOT WORKING
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
May 05, 2009 | Sony W880i Cellular Phone
Hp pavilion ze5500 display monitor still doesn't work
IT could be a motherboard problem with the function key that controls the switching of the video infomation between the LCD screen and the external video connector.
It could be the function key circuitry on the motherboard that controls the back lighting levels on the LCD.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
Canon powershot A80 camera. LCD display works fine but no picture. Camera will take pictures but no display and nothing but black appears on download. Everything else works fine. I think it is the lense?
Sounds like the CCD or the Shutter are not working. Canon only sells the CCD as part of the optical unit, which includes the shutter. However the new optical unit will require reprogramming of the main pcb to focus correctly
Nov 11, 2008 | Cameras
Motorazor V3 External Display not working
hi racie,
1st i want to tell u that there are 2 types of diplay in flip mobiles like urs. and there are 2 display LCD plates/chips inside it.
One of the LCD plate/chip of the external display is damaged. It is due to hard flipping of the mobiles.
I recommend u to go to mobile technician coz it is a physical problem.
Looking for ur kind feedback,
Sajan (sajwhat_2003@yahoo.com / sajwhat@hotmail.com)
May 05, 2008 | Motorola Mobility RAZR V3
Hotpoint wt960p lcd display very dim ...machine works fine otherwise
Assuming that there is no provision for a panel darkening mode...the panel LCD is probably bad. You might try accessing the unit and unplug/replug in each connector. Sometimes, this will help. Be sure the wall plug is removed before doing this.
Mar 31, 2008 | Hotpoint Ultima WF860 Front Load Washer
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Kenwood KDC-MP632 CD Player Logo
69 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
