Sharp aquos lc26sh12u no menu screen appears
I am working on a 26 inch lcd flat panel. It started blowing a fuse and would blow fuse again as soon as replaced the fuse so i replaced faulty parts by exchanging parts with another lc26sh12u i had with a broken screen. Now fuse no longer blows and tv powers on but all i get is a blue screen and no menu or any kind of display. it will not respond to remote menu commands or any kind of button command. It only turns on and off with remote or with tv buttons can anybody tell me how to fix this problem?
  • 4 more comments
  • David Lowry Feb 20, 2008
    I have a Sharp LC-26SH12U problem is almost the same. my set comes on for about 2 minutes then goes to the blue screen. then if i turn it off and back on, it might run for a minute, then the blue screen. Any idea what might cause this problem?
  • Anonymous Mar 12, 2008
    I have the EXACT same issue as you... just blue screen and doesn't respond to any remote control commands... (except for on/off)
  • isimps Mar 29, 2008
    I also have the same problem, first no video only sound, now nothing, only turns on and off
  • phaedra47 Apr 03, 2009
    I have a sharp aquos lc26sh12u I was watching it and picture went off--still had sound. After unplugging I was hoping for a reset--now no pic or sound. TV powers on, but remote and tv buttons do not work so no pic. any ideas?
  • Anonymous Mar 14, 2014
    Changed batteries on remote and even bought a replacement remote. TV only responds to commands when remote is directly in front of tv and only 12 inches away. Can the sensor be fixed?
  • Anonymous Mar 25, 2014
    Lcd tv on by remote but unable to off by remot ; display/sound can not be start by remot; but blue screen con be start
    Genius:
  • 1,554 Answers
As you have a good screen, I would check ebay for the display controllers as there are so many available after shipment drops and kids with hard toys.
what you have been troubleshooting so far is analog , now its likely a digital issue , all you can look for is the the cpu is running,
is it getting the 5v + and the say 20 or so volts.
Posted on Feb 04, 2008
Horizontal lines showing behind tv menu
Normally the menu is generated in the LCD Control Unit. If your menu looks good, but the defect is behind the menu, I would suspect the Main PCB. Good luck to you. Part# is DUNTKD934FM01-V1.
Jun 17, 2016 | Sharp Aquos LC46D62U 46-Inch 1080p LCD...
Fuse on dynex flat screen pwr bd is fast or slow blow?
I'm not sure what you mean by fast or slow blow. Therefore, I would recommend speaking with Product Support for further assistance:
http://www.dynexproducts.com/contact-us.html
Jan 20, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
After power surge aquos tv won't turn on
hi ther is a overload fuse on the psu board which will blow after a surge of power but to get to it you will have to take the back off
Nov 09, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My sharp aquos lcd tv 32 inch usually gets hard time in turning on coz once a brownout occurs and when i turn it on only the green light appears without pictures so i have to unplug it on and off as...
Sounds like you have bad capacitors somewhere in the TV. If none of them are bad, you could also have loose grounding screws on the inverter shield. It is common for this TV and simply retightning them will keep the backlight on again.
Mar 23, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
I dont remember my secret number of my tv lcd sharp aquos 52 inches and i dont know how to reset?
---How to reset secret number---
Press Menu using the remote
Select Parental Ctrl using the remote
PRESS AND HOLD BOTH CH^ and VOL+ AT THE SAME TIME UNTIL THE MESSAGE APPEARS ON THE SCREEN
Nov 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
Fuse F3701 is blow-up after few munites turns on. If replace a fuse F3701 again, it work, but the set turns of any time, check the set: Fuse F3701 is blow again?
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Apr 16, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Televison & Video Logo
896 people viewed this question
Top Televison & Video Experts
Electro Med Services...
