RCA rear veiw projection tv
I have a 1996 RCA 61" rear view projection TV MOD # P60752EB. For a while after i shut it off and it cools down, i turn it back on i have sound but no picture untill it warms up, or so it seems. Now i only have sound but no picture at all.
  • blt01 Feb 05, 2008
    Yes, there is a small glow on all three of them.
    President:
  • 4,402 Answers
Do you see any tiny lites you see on the end of the tubes or crts are the filiments?
Posted on Feb 04, 2008
  • Cary Farah
    Cary Farah Feb 06, 2008
    check these or replace since there are cheap enough
    C4102, C4104, C4108, & CR4118
6ya staff
SOURCE:
I have an RCA rear projection TV MOD: D52W19B SER: E315C30GD Chassis: ITC222. The flyback arcs when power is applied, several days ago the TV was operational, a loud pop emitted from TV, I unplugged it and...
yes it is a flyback transfomer is a very sensitive piece of equipment also known as a lot or lopt in you case i would say that the case has cracked on your flyback you may get by however if the damage inside is not significant yet be wrapping the flyback transformer in black electricians tape but this should not be a permanent solution
Jan 22, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Arc in projection TV
A lot of TV's using CRT tubes have SPARK GAPS, usually on the back of the socket boards. These sometimes arc. None should continue to arc. One snap and that is it...
Dec 29, 2009 | RCA P52926 52" Rear Projection Television
Rca model HD50LPW164YX2 cooling fan sounds
the fan is old and, is off balance (noisy) it can't keep your tv cool so the tv shuts off
open the tv and, remove the fan. replace it with one off e-bay
Sep 10, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p60752eb
Sounds like the flyback, can you look on the rear tag and let me know which chassis you have and verify your model number and I will post which flyback you need as well as where to get a replacement with free tech support to help you install it.
Jul 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Feb 11, 2008 | RCA P61960 61" Rear Projection Television
My rca model P60752EB does not turn on.
this particular rca also know as a itc222 chasis has a safety shutdown cuircit.. if it detect any problem. high voltage. over current over voltage ..one of 20 problems. it will shut down. if the unit tries to come on that idicates its more than just a fuse. first question u ask is after the set been unplug for 30 minites then plug back up does the set come on or try to come on does the led light flash on the front. does it try to come on 3 times then shut down. there is special diagnostic equipment techs used to read errors recorded in the processor.
Feb 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
