Question about JVC KD-G320 CD Player
Settings I can't figure out how to get to my subwoofer settings on my stereo. Help?
  • Anonymous Mar 25, 2008
    how can i change my subwoofer output
  • honda305 Jan 07, 2009
    i have a jvc kd g320 how u hook up the subs
  • 86 Answers
If you could send me the model # i can possible help u out, since most are diff, or just specifiy little more details an i could help, ive hooked up numerus systems 4 family an friends
Posted on Oct 14, 2008
Hola, nesesito ayuda para poner la hora a mi estereo jvc kd-g320 ya le busque por todos lados y no le encuentro.. si alguien puede ayudarme, se lo agradecere... gracias.
6ya staff
SOURCE:
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
How to set a RX-V440 in order to be able
Check the settings. refer to its user manual.
Jun 03, 2012 | Yamaha Audio Players & Recorders
Sound on the speaker is very low voices are barely audible. have tried all eq settings but sound remains low please help
Look through your receiver's DSP sound settings. When you locate the volume control for the center channel, adjust it to be in balance with the music and sound FX. Often, I just forget about the DSP and run the sound in stereo with subwoofer. Helps to minimize the different audio mixes between different TV STATIONS AND DVDs.
Oct 06, 2010 | Cerwin Vega E-76C Center Speaker
Stereo does not store adjusted audio settings and restarts after being turned off
Check to make sure the yellow from the stereo harness is connected to constant battery, connected to the battery, when the ignition switch is off, the yellow wire still has power. The yellow wire is for the memory for the stereo settings and radio station presets.
May 16, 2010 | Car Audio & Video
Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Jul 06, 2009 | Car Audio & Video
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
No sound form aspire 6935g subwoofer
You may want to check the speaker settings themselves within the control panel (Sound Audio Devices + hit the Advanced button under speaker settings). Chances are the current setting is for stereo desktop speakers, you should change it to settings that more closely match your hardware setup...
Post your results here.
Apr 01, 2009 | Acer (54.AA806.001) Sound Card
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    When my daughter turns her car audio off, we loose preset stations.
    Two questions to narrow this down - one, is it an aftermarket stereo, or a factory one? Two, with the key out of the car, can the stereo be turned on?
    If it's aftermarket and it powers on when the key is off, then it's likely two wires are reversed in the harness behind the deck - the constant 12v wire and the switched 12v wire. The constant one is the yellow one, which always supplies power to the deck, keeping power there for the preset memory and the tone settings. The ignition-switched one is so that when the key is turned off, the stereo shuts off (this is the red wire on the harness). If these were reversed, the stereo would always be able to be turned on, and power to the memory settings would be lost when the key is turned off.
    Sep 10, 2008 | Car Audio & Video
    JVC KD-G320 CD Player Logo
    211 people viewed this question
    Top JVC Car Audio & Video Experts
    xxxxxx xxx
    Dalynn Turner
    Marvin
    Marvin
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
