Question about Compaq Inkjet IJ650 Printer
"Printing" fine, but no ink is output.
I have had this IJ650 for a while. It was in storage for about three years with the black and color cartridges in it (oops).
I now have it successfully installed to my Windows XP PC and it responds appropriately to printing jobs - the right amount of paper feeds through and I can hear the printer carriage moving in a rhythm consistent with what should appear on the page.
There is a problem--no ink is put on the paper. I changed out both ink cartridges with no change in behavior. I suspect that the inkjets may have become clogged/damaged during storage with the cartridges installed, but welcome other opinions.
My questions:
(1) If clogged jets is likely my problem, how do I fix it?
(2) If it is something else, what next?
(3) Is this printer as outdated as I suspect?
(4) If so, what is a good new printer that is simple and reliable?
Thank you for your help.
Nate
  • Modicus Feb 06, 2008
    This printer will not print in black. When a black and white page is printed, it comes out in faint and spotty blues and reds. Print head cleaning cycle prints out crisp and bright cyan, blue and yellow bars, but no black. Manual cleaning resolved failure to print yellow.
  • For1smile Feb 10, 2008
    Have the same problem that the printer will not apply ink to the page, when I can hear it moving across the page but there is not ink on the page when done. It prints the test page fine, but will not print the aliment page and doc's, Please anyone have any idea's Please!
    Scholar:
  • 79 Answers
Try replacing the ink cartridges with new ones. Check to see if the contacts that touch the gold plates on the cartridge are dirty and if they are use rubbing alcohol to clean them. Check ebay for cheap cartridges as the official cartridges are not worth it for a printer this old. If that fails to fix the problem then throw the printer away. With a print speed of 1 ppm color at high quality setting you might as well get a cheap canon printer. Lexmark printers ink cartridges tend to clog easily which is why your compaq (Which is a lexmark in disguise) clogged.
Hope this helps
Thanks for reading!
PS i recommend the CANON PIXMA ip3500
Posted on May 01, 2008
Same printer model with same problem as previously listed, printer goes through the motions but "no ink on page"!
Posted on Mar 11, 2008
I want to know what inkjet i require for lJ650 printer please. any assistance would be helpful. thanks
Hi There, This printer is a Reamed LEXMARK Printer. they have all the printer inks for this unit on
http://www.inkjetonline.com.au/lexmark-compaq-ij650/
you can get high yield and twin packs here as well for the Color and Black cartriges.
if you are outside of Australia the ink tanks should be named the same just a different price so for the BLACK INK its a
Lexmark No 16 Black Ink Cartridge 10N0016
and for the colour ink its a
Lexmark No 26 Colour Ink Cartridge 10N0026
Hope this Helps
Feb 15, 2011 | Compaq Inkjet IJ650 Printer
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Compaq IJ650 ink jet printer will not print color.
Just because it’s new does not mean New Old Stock. Your print head is plugged. No if or buts about it. Contact HP and tell them you situation. If they don’t help you, box it up and take it back. Buy an Epson.
Jan 08, 2009 | Compaq Inkjet IJ650 Printer
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Compaq Inkjet IJ650 Printer Logo
199 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
