This appears to be a common problem as I peruse these threads, but I'm at a loss what to do.
Basically the blue ring is the only thing that goes on. I have tried pressing record and menu button when locked , "Welcome to recovery mode " does comes on, I plug USB cable in but my computer but it will not recognise it.
I have downloaded e200w01.00.12 tool but to run this program my computer needs to recognise player first.
What do I do ?
Any help would very much appreciated
Frank
You can enter recovery mode by first:
Making sure the player is off
Push the hold switch towards the headphone jack so you see orange
Press and hold record on the left of the player
With record still being held down, plug into the computer
Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware. You will probably need to contact sandisk so they can give you the link to the file.
Hi. Well, my player was fine today until i turned it off and then tried to open it up again several hours later. i tried to turn it on when it was on hold, so of course it went to automatic shutdown. so then i took off the hold switch and tried to turn the player on, but i got no response. i then tried to plug the UBS cable into the computer, but the computer doesn't recognize it and the player won't turn on even when i put on the hold switch, press and hold the record button, and plug it into the computer. If you can help, i would greatly appreciate it. Thanks!
Medjine
if it is charging it is functoning then after removing i it is not funciton
