Question about Apple iPod nano
IPod Nano FROZE
I accidentally dropped my iPod only 2ft. above the ground. Then, it froze, no sound, and the screen was stuck. I already toggled the hold button and pressed the menu and center button, and that made it shut down. My question is HOW CAN I TURN IT BACK ON??? When I plug it into the mac, iTunes doesn't recognise it, so the mac thinks it's simply not there. My iPod is an iPod nano, second generation 2GB Silver.
  • Sunaka Feb 04, 2008
    One more thing, I've only had this iPod for 2 months...
  • Anonymous Feb 09, 2008
    1. hang problem
    Scholar:
  • 103 Answers
Have you tried removing the battery for about a minute, then replacing it and trying to turn it on? Unfortunately, little things like this are great, but very susceptible to vibration.
Hope this helps, and please remember to rate my answer, good OR bad.
Posted on Feb 04, 2008
6ya staff
SOURCE:
My nano ipod is locked and froze how can i unlock it
Try this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal, and you can now ty re-syncing your ipod in itunes. Hope this helps you!
Feb 10, 2010 | Apple iPod nano MP3 Player
Ipod nano 3rd generation has froze on main screen wont charge of respond to anything screen still lit
HEres what u have to do if ur Ipod nano froze on main screen try turning it off then shorten off the bateryes or if that does not work dont touch it for some hours if u do this then it will work if it doesnt work tell me
Dec 20, 2009 | Apple iPod nano 3rd Generation
My ipod screen froze with an apple symbol on the screen
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
If you want more details, go to:
http://manuals.info.apple.com/en_US/iPod_nano_4th_gen_UserGuide.pdf
Jun 07, 2009 | Apple iPod nano MP3 Player
Ipod 5th Generation Video froze and is now dead
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 26, 2009 | Apple iPod nano 3rd Generation
Ipod froze
Try this which should reset your ipod: First, toggle your hold switch back and forward and put it back to the off position. Then press and hold the menu button and the center button simultaneously for about six seconds and the screen should go blank and the apple logo should appear. After that it should work.
Mar 05, 2009 | Apple iPod nano
Broken ipod
To reset an iPod Nano
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 10, 2009 | Apple iPod nano
My ipod froze wen i waz charging it
Dec 28, 2008 | Apple IPod nano Second Generation MP3...
The wheel doesnt work or the buttons it seems like it is froze or stuck on the screen
try to reset ipod
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 20, 2008 | Apple iPod nano
I have a 8gb ipod nanm and recently it froze and won't move or
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Nov 15, 2008 | Apple iPod nano
Ipod nano
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jun 14, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
