Question about Acer TravelMate 2300 Notebook
Travelmate 2310 keyboard and touchpad problem
My keyboard and touchpad does not respond. But when I remove the battery and use the power adapter alone, they work. Perhaps I need to replace the battery. In the meantime, is there something I could do?
  • Dilwsi Mar 01, 2008
    I have the exact same problem, do i just need a new battery then.
    Can I ask how you know this.
  • 3 Answers
Boot up the system (without the battery).
When the system runs normaly then place the battery on its normal bay.
Shut down bij removing the power from the system.
* Make sure you have not installed any Windows power saving tools, meaning let it run on the battery till it dies *
Wait till the systems shuts down by itself.
Boot your system again (with the battery in its bay and everything will work out fine.
Shuting down by removing the power support (AC) booting up AND your keyboard with touchpad will work again.
So intill you have a new battery, you need to shut-down by removing the AC power and leave the battery in its bay.
You can not shut-down on the normal way any more untill you have replaced the battery.
Posted on Feb 14, 2008
Did anyone contacted Acer for a fix?
Posted on May 19, 2008
  • 60 Answers
Is there anything else on the machine that doesnt work properly when on battery? Sounds very odd!
CMOS battery is bad
Replacing CMOS battery in Acer TravelMate 529TXV step by step: 1. remove all power sources (unplug cable, remove battery) 2. remove keyboard (carefully!!) by unsnapping it at the snaps upper and lower edge 3. in central part you see a metal cover mounted with 2 screws - unscrew those and slide the cower slightly downward (in the direction of the touchpad) to remove it. 4. You can now see a small battery, that is now very easy to remove. Take it to a nearest battery shop, buy one with EXACTLY THE SAME PARAMETERS! and reverse the whole process.
Aug 27, 2011 | Acer TravelMate 529TXV PC Notebook
Acer 2310 travelmate, power button will not go on. There is no sound of a fan. It is in effect dead. Tried different outlet with no improvement. Unplugged everything and replugged it in.
ok, if there is no indecation that there is any power, I mean even no instant flash when you first try turning it on... sometime the power plug in the back gets loose inside. or the power adapter dies... I would try gently weglling the power plug while looking at the lights if anything happen then it is the plug. if nothing then I would try to test the adapter either by a multimeter or borrowing another adapter and seeing what happend... also try disconnecting the power and take the battery out, wait few seconds then put the battery back, then the adapter (all while looking at the lights) then try again.. still if nothing then it maybe the main board itself... best of luck
Jan 25, 2011 | Acer TravelMate 2300 Notebook
My (older) TravelMate 212TX has problems with some keys from the keyboard. I found links that it had to do with the battery and adapter: Disconnecting the adapter and then dismount the battery would...
this at a basic level is more likely to be due to someone spilling a cup of coffee over the keyboard,In which case try to remove ,gently and clean under the keyboard,Wash plastic parts in a weak solution of detergent and replace .dont force any keys or they will break
Sep 07, 2010 | Acer TravelMate 212TX Notebook
How do i change the cmos battery in a travelmate c110. The time and date and bios settings keep changing. Figure it needs a cmos battery. thanks
The cmos battery is exactly located beneath in between the touchpad and speaker, it's a meticulous job, you could see a twin cable leading through the keyboard area. After removing the keyboard, cut the battery wires at the edge of the old battery and replace the new sealed pack by soldering its wires to the same connection. Be cautioned not to break off the slim edges of the keyboard sides by attempting to reach the battery while lifting up top silver panel from the front near the Infrared.
Nov 12, 2009 | Acer TravelMate C110 Tablet PC
Wher is time battery acer travetmate 521te
Here is the link to the service manual, the RTC battery is located under the keyboard and under a heatsink plate. Remove the keyboard and then just above the touchpad is a shiney plate, remove that and the battery is in a socket, you can just pry it up. The battery removal is on page 59.
http://tim.id.au/laptops/acer/travelmate%20520.pdf
Oct 04, 2009 | Computers & Internet
Touchpad is not responding and keyboard
Try shutting down the device and taking out the battery for 10ish seconds. Reinsert it, and power up your laptop. Sometimes this method takes 2 tries, but usually corrects the power/allotment conflicts keyboards and touchpads have with HP motherboards.
Aug 20, 2009 | HP Compaq nc6220 Notebook
Acer Aspire 4930G Keyboard touchpad not responding? Cursor responds with external mouse, keyboard responds in dos mode. keyboard and touchpad are not present in device manager, system restore is useless in...
in my opinion. your touchpad driver is defected by virouse /re install once time it, second your computer touch pad hardwere is damage,check it using by another keyboard and mouse. then u can get result --thanks
Jun 13, 2009 | Acer Aspire 5101WLMi Notebook
My laptop freezes in the middle of doing anything therefore I cant get anything done.
run a spyware removal program on the computer and see if that helps. also what is the make and model of the computer as well as the operating system you are using
Dec 16, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
738 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
