Question about ASTVision 20P 21 in.CRT Conventional Monitor
ASTVision 20P 21 in.CRT Conventional Monitor?
Where can i purchase a power cord/connection cord for mymonitor
    Genius:
  • 1,554 Answers
The power cord can be purchased anywhere as it is standard 3 wire block connector.
radio shack , computer store, goodwill, garage sells,
tv stores,
Posted on Feb 04, 2008
Inspiron 620 desktop will not power on. Change out of power cord was done whilst under warranty (7/12-7/13). Purchased 7/13. Warranty is up. Have not tried to power on since August--it powered up then....
A computer will not power on in certain conditions follows
  • RAM Failure. i.e, RAM is not properly inserted into the port, or any dust particle presence in its port, I am sorry to say The RAM is in DEAD condition
  • Mother Board Failure. Any overflow of power enters into the motherboard. motherboard will burnout (due to lightning, Voltage level increasing etc)
  • Power Failure
  1. When the power cord is properly functioned or loose connection
  2. SMPS is under malfunctioning (SMPS Burn out)
  3. Power cords from smps to mother board,HDD,CD drive fail
  4. Short circuits etc
Check it out...
Jan 22, 2014 | Dell Inspiron 620 ST Desktop Computer...
I need to purchase the power cord and attachment cord
You can purchase these cables at a camera or computer shop. Take your camera with you when you go to the shop so you can get the correct cable.
Mar 20, 2013 | Concord Camera Eye-Q Duo 2000 Digital...
Charging cord missing
The charger manufacturer is Clore Automotive. The part number is ESA26 (http://www.cloreautomotive.com/sku.php?id=274).
If you know anything about electronics, you can determine the input voltage and current requirements for the charger and purchase a generic power pack. The cord connection to the charger can be matched and purchased from an electronic store like FRYs.
Oct 24, 2012 | Solar ES1224 Truck PAC 3200 Peak Amp,...
NEED POWER CORD FOR HARMANKARDON MODEL#nu40-2160150-13. input:100-240v 1.2a OUTPUT=16v=1.5A
I found this site. You need what appears to be the power cord for the Soundsticks II. You must get that part right, either original Soundsticks, II, or III.
http://www.impactcomputers.com/nu40-2160150-i3.html
I need the little plastic part that connects to this power cord. It's the piece that is connected to one of the soundsticks speakers, with the three pins.
I would appreciate knowing what the name of that part is, so that I can purchase it.
I find the price ridiculous for this power cord, and it was more than $200, prior!
Best of luck!
Nov 24, 2010 | Audio Players & Recorders
The power supply cord does not charge or supply power to the laptop. I purchased a new power cord only to find out that it is an internal issue. What part do I need to replace the internal power supply?
in all likelyhood it's the connect that the power cord plugs into. the soldering often fails in that area. it needs to be resoldered to make a good connection
Mar 28, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Need to purchase a power cord and the cord that connects the printer to the computer for a HP LaserJet 6p Printer, Model C3980A. jmtthompson@yahoo.com
Power Cord = 8120-6805
Parallel Cable = 5063-1254
With these part numbers you should be able to purchase them anywhere that sells HP parts.
Aug 03, 2009 | HP LaserJet 6p Printer
Power cord shorts out
Three possible issues,
1. the cord is bad, to test this go to local PC shop and buy a universal power cord test it with this cord. If it works then your cord was bad and you have purchased the correct part. If it doesnt work return cord for a refund.
2. The connector inside the laptop that the power cord connects to is loose and has a short in it. If its loose take it to a PC Shop that knows how to solder and have them reconnect it securely.
3. The laptop has incurred internal damage possibly from a fall or ruff handling. If this is the case the Motherboard may need to be replaced. If this is the case consider purchasing a new laptop.
Hope this helps,
ArmyMason
Feb 26, 2009 | Dell Inspiron B120 Notebook
Mymonitor started flickering constantly,just started,help
I do not want to pay for assistance, my monitor is under warranty. I want to know where i need to call or go to have monitor repaired or speak to someone "without having to pay".That is not under the warranty,having to pay to speak to someone just to find out what the trouble is,,,my goodness? I already know there is a problem, i dont have to may 10$ or 20$, that is what the warranty is for,to have the "problem-the monitor fixed"to know where to send it to or where they can can send fed-ex or a courier to pick it up or i can take it to a "geek squad"......That should be a "free advise from the Proview company".
Dec 07, 2008 | Proview PL926WBi 19" LCD Monitor
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
ASTVision 20P 21 in.CRT Conventional Monitor Logo
187 people viewed this question
Top AST Computers & Internet Experts
David Payne
David Payne
Are you an AST Computer and Internet Expert? Answer questions, earn points and help others
