Question about Sharp Actius AL27 Notebook
Computer starts and stops within seconds but batt light is solid green and pluged in
When I try to start my laptop the power light comes on with the solid green battery light and goes off and will not start up and run however the battery light is green and the laptop is plugged in.
This is cause by the suspend button lock in and not reuturn to
off position. 100% will fix problem.
Posted on May 20, 2008
  • 4 Answers
Ensure That your Power button is clicking back and staying connected - this would cause the computer to shut down immediately.
Posted on Feb 04, 2008
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
D600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Dec 09, 2009 | Dell Computers & Internet
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
At Dell screen the d600 shuts off
GO INTO THE BIOS AND RESET TO DEFAULT SET UP SETTING.RICHARDM69
Dec 15, 2008 | Dell Latitude D600 Notebook
DELL 17' MONITOR STATUS LIGHT FLASHES, BUT WON'T COME ON
Sounds like capacitors in the power supply. Open it up and check for any swolen Caps.
Aug 14, 2008 | Dell E173FP 17" LCD Monitor
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
Sharp Actius AL27 Notebook Logo
339 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
