Question about Panasonic KX-P2023 Matrix Printer
When I turn on the printer and instruct it to print, the print unit with a new cartridge is stuck in the far left position, and the lights on both sides of the Font blink rapidly, five lights.
It was working fine until this suddenly happened. Now it refuses to print.
Suggestions?
Thanks,
Bente
  • 54 Answers
Hai
apply some oil to the rod . keep the head postion in the last. Try to print with out the ribbon catriage
thank u
Posted on Feb 04, 2008
Printer ribbom
Maybe the printer ribbon didn't install properly.
Or
Ribbon Base Unit in fault
Oct 14, 2014 | Panasonic KX-P2023 Matrix Printer
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
Carrige goes to extreme right and chatters. this occured just after cleaning, had worked fine before the cleaning
Alignment is off on the slider track that the carriage moves left/right on. Power down, move the carriage to the far left. power back on and let the system calibrate. There should be a reset sequence where you hold down the menu or online button and keep it down while you turn the unit on. That will put it in a self test mode that you can cancel by powering off then back on.
Jul 26, 2009 | Panasonic KX-P2023 Matrix Printer
I am printing individual labels and want the stop after printing the label - goes down 4 or 5 labels
You have to go into your printer settings and change the size of the "paper" you are printing to so that it matches the size of the labels you are printing to.
Jul 15, 2009 | Panasonic KX-P2023 Matrix Printer
Prints one line per page
check your printer settings. go to preview print page before printing. Might have to uninstall printer and reinstall it again. Hope that helps You.
May 24, 2009 | Panasonic KX-P2023 Matrix Printer
Kx-p2023 vibration
You probably have a power supply problem and searching for the failed part requires some knowledge and a couple pieces of test equipment.
The vibration is liekly caused because a DC voltage produced inside has AC ripple on it because of a failed part, probably a bad capacitor.
Apr 21, 2008 | Panasonic KX-P2023 Matrix Printer
Won't Print At All
First check that the head gap is set to forward position. Usually lever on side of printer. Do a test print by holding in the Linefeed button while switching on. If still no print, loosen the printhead and check for opstruction or loose cable.
Feb 11, 2008 | Panasonic KX-P2023 Matrix Printer
Panasonic kx p2023 with a Mac system os x10.39
When you add the printer in Mac select Epson LQ850 driver or install the Generic Text driver. That is your most basic driver for all operating systems
Nov 08, 2007 | Panasonic KX-P2023 Matrix Printer
Panasonic KX-P2023 Matrix Printer Logo
123 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
