Question about Cell Phones
LG KG800 charging problem.
My new LG KG800 has a big problem. I caharge it hours and hours. It never charges.Once it said it is fully charged. I took it off from charging and turn on. it turned of in one second showed low battery.Even I tried two different battery.
Is there anyway to fix it?
I have LG L342i mobile phone - every time I plugged in the charger - screen flashed on with charging symbol but only last for a couple seconds and then off. I have left it to charge for two days - when unplugged the phone would not turn on.
Would anyone know what the problem is? is something wrong with the battery that it could not hold charge?
  • 1 more comment
  • tuan Feb 04, 2008
    Hello jhanmel,
    How do I reset the factory setting and/or reinstall software for this phone (LG L342i)?
    Many thanks for your advice so far.
  • tuan Feb 04, 2008
    Thank you jhanmel,
    The phone is currently not able to switch on - does not matter how long I charged the phone and therefore reset to factory setting is currently out of the question.
    I will see what I can do in getting the software re-install via a service center.
    Many thanks.
  • Anonymous Mar 18, 2014
    my lg phones power button fell out and I replaced it with another phones button now my phone says low temp. can not charge. sometimes my phone will turn on and stay on but other times it just shows that I need to insert my battery and the battery is in the phone
    Problem Solver:
  • 19 Answers
If you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
Posted on Feb 04, 2008
  • glennmel morco
    glennmel morco Feb 04, 2008
    factory setting is available only if your phone is on; you can find it in the setting option of your phone; and if dosn't work reinstall softwer; you have to bring your phone to the service center; but if you have a dct3 and dct 4 and a softwere of lg phone you can try it' but its to difficult'
  • glennmel morco
    ok thanks
Battery time is very low and on the other hand at a time msgs cannot be sent to many contacts. i have to forward msgs one by one?
First of all i will recommend that you purchase a new battery.
When you do get a new battery make sure to charge for 6 hours with the phone turned off.
Now for the subsequent 3 caharges make sure the phone battery is completely drained (it turns off by itself). Perform this at least once every month.
Note that after the first time charge practice a full charge and trickle charge. This means that you first turn the phone off whiles charging for some time and later turn it on to finish the charging. You can do this from time to time but should not be done always when charging.
When it come to the messaging i will advice you check you messaging settings for more help.
click on the link below or copy into the browser should you need the manual
http://nds1.nokia.com/phones/files/guides/Nokia_E71-1_UG_en.pdf
Dec 07, 2010 | Nokia E71 Smartphone
LG KG 800 hp won't switch on
You can try holding the power and volume down buttons at the same time for up to 2 minutes to see if it will power on. Could be time for a new phone if that doesn't work.
May 04, 2017 | LG KG800 Cellular Phone
Help
my phone LG KG 800 is charging is not stored i am charging full but only two hours back up getting battery is new pls how to rectify this problem pls help any one
Azeem
cell : +91-9985980830
Aug 28, 2008 | LG KG800 Cellular Phone
LG Chocolate
dont listen to the other guy you would not get three batteries wet unless your dumb... it is probably a cracked circuit board in your phone
Mar 10, 2008 | LG KG800 Cellular Phone
Won't charge
first of all check ur charger
then battery
and then battery connector
Feb 08, 2008 | LG KG800 Cellular Phone
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
Jan 21, 2008 | LG KG800 Cellular Phone
Lg chocolate
hold the end key to turn on.. if nothing happens plug it in.. i had to charge mine for abour 2 1/2 hours before it would work
Dec 25, 2007 | LG KG800 Cellular Phone
Phone won't turn on
slide up your phone and hold down the off button
Oct 26, 2007 | LG KG800 Cellular Phone
Cell Phones Logo
631 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
