Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
Kv34hs510 after replacing both MCZ3001DB chips and TV still will not power up ,what would be the next step in fixing this model tv. kV34-HS510
3 Suggested Answers
sdporto
  • 15 Answers
SOURCE: sony KV34-HS510
tv is in protection mode...first u most measure psu output, next horizontal transistor driver, and all outupts from flyback....and find witch one is in fault
Posted on Feb 04, 2008
daniel719
  • 240 Answers
SOURCE: sony trinitronKV34-HS510 3 blink code
i dont think its HV
3 blinks is B+ voltage.
just replace the main board.
sum times andrews electronics has them for around $80
regards,
daniel.
Posted on Jan 13, 2009
My sony tv 34 inches model kv34*90 become colors yellow
Hello
Just mention the full model number of your Sony TV. There will be some more letters follow [KV34-----]. Send it clearly to me by Fixya. Even though it is 34" TV, these suffixes are important for trouble shooting.OK.
Mar 06, 2011 | Televison & Video
I need mczz3001d OR mcz3001db IC but not found in local market, can I have any replacement of the above IC
Search on eBay or elsewhere for part number MCZ3001D **or** MCZ3001DB I understand the "DB" part may be an upgraded revision of the original "D" part. I am in the same boat -- 7 blinks on the Standby light. I plan to buy these parts and attempt to fix it myself. I recommend buying the DIP sockets not just the chips themselves, it should be easier and should make it easier to replace in the future if it happens again.
Feb 16, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Kv-34hs420 Standby light blinks 6 times. Power supply issues?
Replace IC6501 and IC8002 at same time, both have same number and located parallel on DZ board. Part number is as follows..
670581001 MCZ3001DB
Available in Part Store.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a 2004 Sony Wega Trinitron KV-HS510 that will not turn on. When I try to turn on the TV it sounds like it will power up and then I hear a click, and the TV turns itself off. The Stand By Light is...
7X blink is a generic Horizontal Deflection Stop code. There is a chip in the TV, IC8005 or 8006 if I'm correct, that routinely goes bad on these sets. It could be one of any number of transistors or IC's, but that one is usually the culprit.
The chip itself is around 40 dollars, and with labor, you're looking at about 125-175 average, barring any unforseen problems. That's in-shop. Tack on a service call charge if it is in-home (if anyone will do that for you).
Hope this helps you...
Jan 07, 2009 | Televison & Video
SONY KV32F-Q86U BLINKING 16 TIMES
The problem, on the AE6B chassis at least, is usually an MCZ3001DB chip. There are three in the average Sony TV, one on the so-called A-Board and 2 on the D-Board. Usually the problem is caused by a faulty one on the D-Board near the two large switching FET's. In this case, replacing this will fix the problem.
Brian.
Nov 03, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitronKV34-HS510 3 blink code
i dont think its HV
regards,
daniel.
Feb 05, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV34-HS510
TV's always make a clicking sound as the Main Power relay turns on. If you are asking why it then doesn't turn on, it can be many things. The processor monitors a number of circuits and if something is amiss, it turns off. The most common failure is the high-voltage circuit and if the set is any where near 10 years old, I'd plan on replacing the flyback transformer as well as anything else it damaged while failing.
Another option is to wholesale replace the main board from an outfit like PTS Electronics at ptscorp.com.
Hope Ya Fix It!
Feb 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV34-HS510
Feb 04, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
