Question about Hitachi C21 F800S TV
Please help!!! Hello! I recently purchased a new Hitachi C21 F800S TV. However, I was not aware it was made in Japan. The company sent me an adapter for the extension cord. But, I can't figure out how to connect my cable service to the set. Could you please provide instructions to me, whether I need to buy another accessory piece, or what I can do? I haven?t had the opportunity to even see what the picture looks like yet.
  • 2 more comments
  • Lea J Feb 04, 2008
    I'm sorry but I do not understand. I am trying to connect my cable service, such as HBO, SHOWTIME, etc., but I don't know if I need to buy another adapter or what type I should buy, and where it should go on the back of the TV.
    What is RCA's? How does cable service, like Comcast, Time Warner, Cablevision, etc., get connected to the TV? Please explain.
    Yes that is correct.
    Okay, I appreciate the information. But does it work for the Hitachi C21 F800S TV model? I know how most tv sets have the outline that you sent. But this televison is completely different. So you are saying I need a coaxial cable, the one without the needle in the middle?
    Genius:
  • 3,422 Answers
What you need to connect your television:
  • A cable-ready television and the manuals that came with the set.
  • An RG6 quad shield coaxial cable with "F" connectors at both ends (This is a common cable that you probably already have.)
Getting your television connected:
  1. Plug TV into electric outlet.
  2. Connect one end of RG6 cable into the back of your TV and connect the other end of the RG6 cable into the cable jack of the EagleNet box. The EagleNet box is located on your wall. The cable connection has an icon of a TV above it.
  3. Turn TV on and set TV to "CATV" mode.
    You must make sure the TV is set to CATV mode. Some TVs do this through an on-screen programming feature. Others have a switch on the side or the back of the TV set. Consult your TV's manuals.
  4. You should now see a clear picture.
    • If you don't, contact your R.A. or call x2-HELP (2-4357) to report a problem. If you call x2-HELP, staff may be on other calls. Leave a voice mail message with your name, phone number, residence hall, room # EagleNet box # and a brief description of the problem.
    • If you are only receiving the first 13 channels, your TV isn't in CATV mode yet. Check this first before you call for help.
    • If you are only receiving the first 35 or 36 channels, your TV is too old and isn't capable of receiving 60+ channels. If you have a cable-ready VCR, you can try using the VCR to tune the channels by connecting the VCR to the EagleNet jack and then the TV to the VCR. *See note below
If you have a VCR or DVD player:
  • You may need a 1000 mhz cable splitter. See notes below.
  • An RG6 quad shield coaxial cable (see above)
  • VCR or DVD Manual
  • Due to the vast variety of VCR and DVD Player types and functions, Information Technology Services cannot offer support for VCRs or DVD Players. Consult your owner manuals for assistance.
VCR/DVD notes:
  1. Plug VCR or DVD Player into electric outlet.
  2. Connect one end of RG6 cable into back of the VCR/DVD and connect other end of into the TV.
Do you need a "splitter"?
A spliter is a small device which allows you to connect two cable devices to the same cable line. You will need this splitter if you want to watch one station and record another at the same time. The setup varies with model of VCR or DVD Player. Any electronics store will have splitters available and can help select the right one.
Goodluck,
please don't forget to rate me as fixya..
Posted on Feb 04, 2008
  • 3 more comments
  • Priya darshan Feb 04, 2008
    Click here to go to timewarner's website and u will understand how it connects..
    Hooking Up
    How do I hookup my TV or VCR to receive UTV cable services?
    Cable
    TV service is already activated in your room - you do not need
    to call anyone for activation. All you need to do is connect
    your cable-ready TV or VCR to your room's wallplate using a coaxial
    cable.
    How to hookup my VCR?
    If you are connecting your VCR to receive UTV cable services, just
    connect your coaxial cable from the wallplate to your VCR INPUT.
    Then connect another coaxial cable from the VCR OUTPUT to the
    INPUT on your TV.
    Here have a look at this:
    Hooking Up
    Cable
    cable.
    INPUT on your TV.
    Yup it works on ur TV too.yes u do need a coaxial cable and it should have a needle in the middle
    If u have ny other problems please ask..
    Hope ur cable gets hooked up to ur TV soon..
    Goodluck once again
  • 667 Answers
Yes, To make the 3 wire hookup since the set has no co-ax input. You'll have to run the cable to another device like a VCR then run the RCA's to the set
  • 1 more comment
  • Kevin Pettit
    Kevin Pettit Feb 04, 2008
    Yes, the cable service is using a black co-axial wire that has a screw on coupler? And there is no place on the TV that this fits correct?
  • Kevin Pettit
    Okay, You need to have another device like a VCR that has that connection, (most do). Connect youe cable to the VCR then you can run 3 wires from the back of the VCR to the set. They are usually color coded, Yellow, Red and White. The plugs on the set should have the same marks
  • Kevin Pettit
    Okay, I found the specs on your TV from the Singapore Hitachi site. The TV does have the co-axial input on the back that should fit the black line with the screw on connector. If your cable box has a different connection than the single line with the 'needle' let me know
    Master:
    Sergeant:
  • 440 Answers
Should be just 3 wire like old one ok match them up red white black if it has ground ok its easy once u see what your doing when u get in there ok thx for using fix ya thx nick .
  • 3 more comments
  • nick helpap
    nick helpap Feb 04, 2008
    well comcast conects via cox cable oonly or hdmi for hd boxes and hdtvs
  • nick helpap
    does the comcast box ect have hdmi out and does yuor tv have hdmi in then u wnan buy hdmi cable ok
  • nick helpap
    does tv hdmi then and unit
  • nick helpap
    use hdmi cable if it has it from tv to from dish box ext best picture
  • nick helpap
    coxial if u wann run vcr use yellow cable red white for sound ok to tv direct
Help needed!!!
Here is a small diagram it shows how to connect the player to a tv. the next thing is are you having problem with the DVD player or Tv? Do you have any problem with dvd player not reading the disc or is it just the connection problem.Any ways please look at the below diagram.
Goodluck..
Feb 17, 2008 | Hitachi C21 F800S TV
Only 1 channel has sound pin 18 has sound pin 15 no sound on ic tda 9859 please help
is that stereo sound? try adjusting the balance control in the remote control...
Feb 14, 2014 | Hitachi C21 F800S TV
Service menu of hitachi tv c21-f800s and c21-sf980
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 02, 2013 | Hitachi Televison & Video
AV NOT WORKING
Video switching IC is faulty.
Sep 02, 2012 | Hitachi C21 F800S TV
Give me str nambar
HITACHI C21 F800S CHASSIS 3P31 SM
http://elektrotanya.com/?q=showresult&megnev2=21T31&kategoria=tv
Go to the above website, get the manual at top, it is a service manual for your chassis, so you should be able to identify, your part.
May 24, 2010 | Hitachi C21 F800S TV
Why does my Tv turn off by its self after turning
power problem. it takes a lot of power to start it up, but the power supply can't do it anymore. needs a new power supply.
Jul 15, 2009 | Hitachi C21 F800S TV
Diagram tv Hitachi C21-F800S
my tv power led is on
but screen not on
pls send diagram
Apr 08, 2008 | Hitachi C21 F800S TV
Assistance needed!!!!!
you have a European pal coax cable connector and need the us version adapter..
Feb 04, 2008 | Hitachi C21 F800S TV
Hitachi C21 F800S TV Logo
135 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
