Question about Nintendo Wii Console
Problem with wii controller charger
I was given a charger for Christmas that charges both my wii remotes. I haven't even had a chance to use the remotes, but today I noticed that the left slot of the charger was glowing a bright blue. When I took the remote out to use it, it didn't work, and it was very warm to the touch. When I took the battery door off, I saw that the battery pack was scorched. I guess I'm lucky that I didn't have a fire because of it. I replaced the battery pack with regular batteries, but now my wii remote won't work. I threw away all the paperwork that came with the charger. Any advice? I think I have the receipt and I might be able to take the charger back to Walmart, but that won't replace my remote that was damaged because of it.
  • jazzmine12 Feb 04, 2008
    The charger unit I received is a double charger - charges two remotes at a time. The charger unit came with two battery packs, which is what I installed in my two controllers. The battery packs are self-contained, so they can't leak. The battery pack that came from the damaged controller has a small burn mark on it. I guess it got too hot in the charger. Sounds like a defect with the charger to me.
  • Slowski62 Aug 25, 2008
    Purchased a total WII package including the double recharger April 2008. Prior to first use we charged batteries per instructions. All working fine until low battery message appeared on a remote. Placed remote in charger and nothing lite up. Seems as though the charger is not receiving a current or battery packs are not getting a connection. Used other outlets and still nothing happens even after wiping metal connections. Any suggestions?
    Novelist:
  • 171 Answers
Sounds like you broke your remote to me. did the batteries leak on your remote? If so, try to clean the contacts on the remote (the spring on one side and the flat one on the other). You may need to use a nail file to scrape off the gunge.
Now, why did this happen? Did you put rechargable batteries in your wiimote before you put it on the charger? And if so, did yo put the CORRECT TYPE of rechargables? There's a big difference between nickle cadmium (Ni-CD), Nickle Metal Hydride (Ni-MH), and Rechargable Alkaline. Putting the wrong type of battery, or a non-rechargable battery into the wrong recharger causes leaking, explosion and fire... as the charger and the batteries warn you of all over.
Posted on Feb 04, 2008
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • Dec 06, 2011 | Nintendo Wii Console
    Getting no lights at all when trying to charge wii remotes.
    Check to see if your charger is plugged in. If it is check the wall plug it is plugged in to with something else. If it is working then chances are your charger is broken and will need to be replaced.
    Mar 20, 2011 | Nintendo Wii Remote Controller
    What to i need to do when the wii charger is green
    If your controller is still sat in the charger then that is fine when the green light is on. The chargers have what is called smart charge technology. This means that when the controllers reach full battery capacity the charger stops sending charge to the controller until it drops below a certain charge level again. Leaving the remotes in the charger when the green light is on will not damage them in any way at all.
    Hope this helps
    Dec 19, 2010 | Nyko Charge Station for Nintendo Wii
    Wii remote is not charging. I have 2 remotes, one of them does not charge. Basically, when I charge it, it charges for a few seconds then it turns to the green light (meaning it's done charging) so it...
    If you have had the "battery" for a long time, it could be that it can no longer carry a charge. Rechargeable batteries' charge grow shorter over time. If you still use the Wii/Wii U regularly, I suggest rechargeable AA batteries+charger (If you don't have them already). AA batteries work in other devices so even if you stop using the Wii, the batteries will still work in remote controls, clocks, flashlights etc unlike a WiiMote Battery pack.
    Sep 10, 2017 | Nintendo Wii Remote Controller
    I have a wii remote charger and have just purchased some rechargeable batteries but they don't appear to be charging, everything is set up correctly but remote only showing 1 light lit and then going dead
    Make sure your charger is plugged in your Wii AND turned on. If you do this, the remotes should charge.
    If the remotes still don't charge, there's a problem.
    May 03, 2010 | Nintendo Wii Remote Controller
    New bright 19.2v nicd battery problem
    I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
    Jan 17, 2009 | New Bright Remote Control Toyota FJ...
    Nintendo Wii Console Logo
    477 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
