Question about NEC MultiSync FE700 17" CRT Monitor
FE700 with double line in the screen
I have 2 lines in the screen , dividing the screen into three parts , plz help me throuth this
As it is a trinitron tube, this two lines are there on each tube, it is nothing to worry about. it is like this, get used to it
Posted on Mar 23, 2008
2 pararell lines on the screen.
What is the nature of these lines? Vertical or Horizontal? Provide more details please.
May 27, 2013 | Sansui Televison & Video
I have a Toshiba Satellite C655. The screen is malfunctioning as you can see. The screen has 3 vertical striped lines which has divided the screen into separate parts. The cursor will not pass through
Did you damage your screen (i.e. step on it, wet it, ect.)? If you did then you might have to take it in for repair. Regardless, you might just need to call a troubleshooting or help line/number, for that particular brand ( i.e. dell, toshiba,ect.)
Jan 02, 2013 | Computers & Internet
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
2X+4Y=-8
2x + 4y = -8 ; divide each side by 2
x + 2y = -4 ; subtract x from both sides
2y = -4 - x ; rearrange
2y = -1x -4 ; divide each side by 2
y = -1/2x - 2 ; relate to slope/intercept form of line (y=mx+b)
implies there are multiple solutions that fall along a line with slope -1/2 and y intercept of -2
Sample points on this line are (-4,0), (-2,-1), (0,-2), (2,-3)
Nov 04, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
My laptop has its screen divided into 8 parts, 6 though but with 2 more smaller parts below. and a fat black vertical line. please help me it Hp pavilion Dv6550ee
sounds like the screen has had damage thru impact
Only solution is to replace the LCD panel
Please rate me thanks
MISTERDJ
Aug 12, 2009 | HP Computers & Internet
Tv went double and green and black lines appeared at the top and bottom of the screen
tv has a condition common in rear projection. the geometry and coincidence of the screen is called convergence. this is regular repair in the workshop. I expecting the fail stops in convergence amplifiers (first step of this critical area) because total convergence out of sinc as you are posting can lead to the control of the convergence previous to the amplifiers (is called digital convergence unit). It can increase the cost of the repair. some testing in the bench can divide this decision. But usuallly a simple damage is one color or two colors distortion, your tv shows three of them because this black area visible top and down.
Apr 16, 2009 | Sony KP-51WS510 51" Rear Projection...
White screen divided in half with black line
Your ccd imager is defective . You need to replace the ccd imager .You need to contact the service center to get one for your camera .
Jan 30, 2009 | Kodak EasyShare Z700 Digital Camera
NEC MultiSync FE700 17" CRT Monitor Logo
69 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
