My 2 year old Thermador Mbbs/01 stopped heating this afternoon. All appears well, but nothing gets hot. I have uplugged it in an effort to "reboot". It still doesn't work. Any suggestions would be appreciated.
-   suddenly makes loud noise and no longer heats!!!!-   Guest
Feb 26, 2009
-   Hi, I am looking right at the LG magnetron and there's no red button to push. If mine doesn't have a red button, can you suggest an alternative? (Or let me know if I'm missing something!). Thanks in advance. -   yobro999
Sep 21, 2008
-   thermador microwave it is pensive but work very poor,-   Guest
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Comments:
Feb 04, 2008
- The trim kit will have to be removed, then the microwave from the cabinet. You will need a tamper proof torx bit to remove the case off the unit. The cutoff in on the mag tube(that part has a lot of fins on it with a fan blowing air thru it to cool it down) push the red button on top the the cutoff to rest. Usually at this point is will put a glass of water in the unit and start it up to make sure it and the fan is running.
I've been told they no longer manufacture replacement parts for my 6year old Thermador Combination...
(More)
I've been told they no longer manufacture replacement parts for my 6year old Thermador Combination Oven Model SMW272ZP. The microwave has crapped out and I would like to find a new matching microwave to fit the same opening. Any thoughts other than just checking dimensions on the internet and crossing my fingers that what I might find will really fit? Thermador offers no help!!!
I have a MBBS, based on your picture (I have a different model # on the inside plate) Unit will...
(More)
I have a MBBS, based on your picture (I have a different model # on the inside plate) Unit will accept time, but when start is pushed, it runs for apprx. 3 seconds and shuts off - displays "cooling"
The inside light of the MBBS microwave died on us. Microwave works fine but no light. I figure I...
(More)
The inside light of the MBBS microwave died on us. Microwave works fine but no light. I figure I should be able to change the bulb - like a refrigerator, right? Well there appears to be no obvious door inside. Outside also has no obvious door on left top and righ sides. Where is the bulb access on this thing?
