TV GUIDE PROGRAM
My TV guide program will not download. It has been over a month.
  • BIGKIDS Mar 01, 2008
    my tv is connected via cable with a cable card / i have 2 42lbdr with cable cards thay work good
    President:
  • 1,284 Answers
Is your TV connected via a cable box or directly to cable without a box? The guide information normally comes from the local PBS station so it is possible they don't run that service anymore.
Posted on Feb 04, 2008
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide - LG.com
www.lg.com/.../32ld345h-commercial-mode-setup-guide....
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/55640-4-program-information
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
Cannot download TV Guide schedule-Verizon FIOS
With this problem I will suggest you to contact Verizon or motorola so they can help you better with this concern this is the number 1-877-466-8646....
Hope that helps.........
Sep 15, 2008 | Panasonic DMR-E85H DVD Recorder
The channel guide only shows no information available most of the time
sidbashford
You are getting that message because the receiver is not updating the Electronic Program Guide (EPG). Try unplugging the receiver from your electrical outlet for about 10 seconds (make sure all lights on receiver go out) and plug back in. This will cause the receiver to reboot and re-acquire satellite signal. Allow it also to download the program guide. After you get your channel back, pull up your guide, go into the future to see if it updated.
If it did not update, you'll need to run a check switch test. Press Menu on your DISH remote; should have Main Menu on TV screen. Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get to Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 26, 2011 | Televison & Video
Every time I try to record a show OR check the DVR scheduled-to-record list, I get this error message: "unable to provide program guide information"
Hi tdarnold90my name is Mike Houston of DISH Network and with the guide not showingprogramming there are some things that can be done. The first thing you willwant to do is unplug the receiver for 10 seconds and it will power back up and reacquirethe signal and download the program guide. After the guide finishes downloadingmake sure you see the programming listed, if there still is no programmingpress the MENU-6-1-1 buttons on the remote and on the Point Dish screen selectCheck Switch and then the Test button. After the test completes exit out of allmenus and it will reacquire the signal and download the program guide and checkthe guide again to make sure programming is listed. If you have any questionsplease e-mail me at Michael.houston@dishnetwork .com.
Feb 14, 2011 | DISH Network ViP 211 DTV Receiver
Comcast TV guide does not download
Have you tried powercycling your box? Checking all the connections making sure they are tight fitting? The guide should always load no matter what.
Apr 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Incorrect date in DirecTV programming guide
on front of receiver, there is a door that you can open. behind the door there is a red reset button. press the red reset. this should fix the problem
Mar 22, 2009 | Hughes HD-DVR250
Dish DVR-625 won't record
More than likely the download was interrupted. Take bot remotes and turn off both tuners. When this is accomplished the blue and geen light will be extinguished. Now you will need to wait about thirty minutes for the receiver to turn back on. When it does it should immediately go to downloading software when this completes you should get a new program guide to download. The process is a bit time consuning but should resolve your issue. Thanks for using Fix Ya.
Jan 09, 2009 | DISH Network DVR-625 DTV Receiver /...
TV PROGRAM GUIDE
delete the epg programe from your archos then when connected to the archos web site through your pc download the updates this should work
Aug 23, 2008 | Archos 605 WiFi Digital Media Player
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide plus flashes on the t.v.. how do you turn it off
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
Oct 17, 2007 | GE 32GT740 32" TV
Televison & Video Logo
404 people viewed this question
Top Televison & Video Experts
Electro Med Services...
