Question about Fuji FinePix 3800 Digital Camera
Zoom Error When I turn the camera on, it shows "zoom error". I can turn it off and try again with the same results. Bud Elder elderb13@earthlink.net
    Genius:
  • 3,422 Answers
Try this out it worked for most of them who had a similar problem like urs:
First remove ur batteries
then Gently tap it twice at the end of the camera to ur plam and it will work again.
just tap it very lightly against the bottom of the camera holding it
upright.
Allow it to cool for some time then put back the batteries..
Goodluck,
Please Don't forget to rate me as fixya.
Posted on Feb 04, 2008
  • Priya darshan Feb 04, 2008
    And if this trick doesn't works then:
    There is no easy fix, you will have either disassemble
    and get dirty, or take to an authorized repair person. This zoom error
    problem is usually caused due to dirt or dust in the zoom mechanism.
    If you think you can handle disassembling the camera then grab a set of gentile screwdrivers and follow these instructions:
    You will have to remove a few circuit boards in order to get to the zoom mechanism.
    Remove the zoom mechanism:
    And the gear box:
    You will
    need to disassemble the gearbox, make your self a drawing or (if you
    have another camera) take pictures of every step of the disassembly in
    order to remember how to reassemble it correctly!
    Place it on a clean table and under a strong light and carefully disassemble:
    You
    should notice some small particles of dirt (sand or grit) on the tiny
    gears, in my experience most zoom error problems are caused by a
    small grain of sand. preventing the gearbox from turning smoothly.
    Carefully Scrape the dirt off with a small clean brush or even a screwdriver and re-assemble the camera.
    Once you put it back together the zoom error should be gone
  • 667 Answers
That is never a good message to see on these types of cameras. Look at the lens area, does it look askew? i.e. not centered, cocked to one side. Did the camera get dropped or bumped recently? The only thing you can try is remove the batteries for a few moments and see if if might be a electronics error rather than a mechanical problem. I can't do chat from my Mac, but I will monitor emails from Fixya
    Scholar:
  • 119 Answers
Try a camera reset first of all.
if not,thanit is little what you can do,because your camera is  acompact one..you just cant get into it.
Try a specialized service because the problem can be solved by replacing the zoom engine if it is brocken.
if it is a lense problem..wellthan is more complicated..
good luck
Fujifilm finepix J32 Zoom error
Had exactly the same problem with my fujifilm j32, after reading a few things on the net and definitely couldn't be bothered to waste money and time sending off a camera that cost a few quid I took matters into my own hands!
I turned the camera on and quickly grabbed the lens to stop it retracting again, once it was held out I gave it a good 'wiggle' moving it in all directions fairly firmly!
I then pressed the on/off button again to switch it off and then turned it back on and low and behold it turned on and worked perfectly after!
Hope this helps others cause it could save you a lot of time and money!
Feb 19, 2010 | Fujitsu Cameras
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
Dec 23, 2007 | Fuji FinePix A205 Digital Camera
Zoom error
when the lens comes out, gently pull it as far as it will go, wiggle it a bit and it should right itself. just tried it with mine and it's sorted.
nice
Nov 07, 2007 | Fuji FinePix A600 Digital Camera
Fuji FinePix 3800 Digital Camera Logo
64 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
