Question about RCA VR637HF VHS VCR
Rca vcr I need help hooking up a vcr to a magnovox tv that has cable hooked up and a sony dvd player. Can you give me instructions on how to hook up the RCA VCR???
  • wpollock3 Feb 04, 2008
    Thanks so much, that did it. I have struggled all night trying to make it work. Thanks, just hope everything else works with the vcr hooked up because last time the vcr was hooked up the tv would not stay on, but we believe that was because of a loose connection. Thanks again. Wendy
  • Anonymous Mar 29, 2014
    NEED OWNER MANUEL
    Scholar:
  • 84 Answers
There a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Posted on Feb 04, 2008
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
HOOKING UP A MAGNOVOX BLUE RAY ,CD PLAYER. WE HAVE COMCAST CABLE.
it gets plugged into the tv not the cable. audio out of dvd into tv and video out of dvd into tv
May 10, 2009 | Televison & Video
Dvd/vcr magnovox mod dv220mw9 has serious apparent tracking probl
how can i hook up magnavox vcr dvd player to whitehouse tv using warner cable connection only.
Mar 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
LOST INSTRUCTIONS HOW TO HOOK UP MY DVD & VCR PLAYER TO MY TV SONY?
Sony maintains most manuals on their website. The general principle is to hook the cables from the video and audio OUT of the DVD/VCR player to the video and audio IN of the TV. Once the cables are hooked up correctly, just press the input, source, av, or video button on the tv or tv remote to change the television to the correct channel so that you can watch videos.
Jun 14, 2008 | Philips Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
RCA VR637HF VHS VCR Logo
572 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
