Sunroof wont slide back and makes a jamming noise... tried opening when frozen ... In the end it will Tilt but wont slide and wont catch the tracks im guesssing. to close need to manually close and is still not fully closed? what should i do
1. Place the ignition switch in the ON position.
2. Push and hold the sunroof switch toward 2 . Once the sunroof has reached the full tilt position, release the switch. Push and hold the switch toward the 2 position again. After a delay of four seconds, the sunroof will make a small movement and backup.
3. Release the switch.
4. Within 5 seconds of releasing the switch, push and continuously hold the switch toward 2 . The sunroof will move from the tilt position to the open position and back to the close position.
When you turn switch to the slide back position, do you hear the motor running ? If yes, might have a blocked or bad track. This will require you to remove trim covers and glass to have access to the track. Once all parts removed, turn the switch to open as you look at the motor and track move.
there is 2 slides on each side that sit in a track its common for on of the slides to pop off the track letting it tilt but not retract if you get it to tilt take a look at the track on both sides one is prolly off pop it on and boom
If your indicating the roof is crooked, that's odd... The roof slides along a channel actuated by a coiled cord.
Both of the cords pass along a gear attached to the Sunroof motor which pulles the cord tooth by tooth, impossible to go crooked unless really jammed or tampered with.
There are two plastic wedges that drop into the plastic slides on the sunroof (the plastic slides are behind the more forward metal slides.)
The plastic slides control the tilt of the roof when moved independantly. The plastic wedges join them.
If the roof moves too far back, it is possible for the wedges to stick up and jam the roof open.
This should never happen, but could if the two switches on the gear fail and no longer provide feedback to the controller indicating the roofs position.
Access to the Sunroof motor requires you to drop the headliner.
To drop the headliner, the plastic pillar shrouds need to be removed front and back, the seatbelt bolts in the middle secion need to be removed, the oh-**** handle, the front visors, and cabin lights.
a couple of ideas for you to try, not sure maybe you have already tried, but yo might use some wd-40 and spray the sliding track and back into the motor area. you might also check the motor that runs the sunroof it could have to high of ohm resistence. not sure if you are hearing a whining noise when you try to operate the sunrood or not, is the noise consistent with the glass opening and once the glass stops moving then do you hear any noise from the motor or anything, or is it just quiet? let me know so i can try to help you out the best i can. thank you for using fixya.
